Age: 12 y.o
Condition: All parts are in working order
Contact: PM with any questions
Comments: I need this stuff gone, im letting it go for cheap.
R33 GTS-T Series 1.5 Differential Cradle w/ Diff & Hicas Rack (ABS) - $200
R33 GTS-T Series 1.5 Front Upper Control Arms - $50
R33 GTS-T Series 1.5 Front Castor Rods - $50
R33 GTS-T Series 1.5 Front Wishbones - $50
R33 GTS-T Series 1.5 Front Brake Hubs w/ Lines - $100
R33 GTS-T Series 1.5 Front Struts w/ Springs - $100
R33 GTS-T Series 1 Inlet Manifold w/ Throttle Body - $50
R33 GTS-T Series 1 Ohlins Rear Struts w/ Dampening Adjustments & Springs - $100
Pictures can be found at:
http://www.skylinesaustralia.com/forums/R3...ts-t238267.html
https://www.sau.com.au/forums/topic/248578-fs-r33-gts-t-parts/
Following items are free :D , pick up only....
Series 1.5 ABS Unit
Series 1.5 Window Washer Bottle x 2
Series 1.5 Overflow Bottle
Series 1.5 Brake Booster
Series 1.5 Clutch Master Cylinder
Series 1.5 Passenger Side Power Window Switch
Series 1.5 Front Windscreen Wiper Motor
Series 1.5 Rear Windscreen Wiper Motor
Series 1.5 Rear Brake Caliper (Side Unknown)
Series 1.5 Rear Brake Rotors
Series 1.5 Pedal Assembly (Clutch, Brake & Accelerator w/ Throttle Cable)
Series 1 Turbo Heat Shield
Series 1 Rear Spoiler
If you want any of these please PM me or SMS me on 0413 351 827
Thanks
  • 3 weeks later...
DaGr81 - yeah mate just give me a call in the morning and we can arrange something
i leave home around 4pm to go to work thats all
**R33 GTS-T Series 1.5 Differential Cradle w/ Diff & Hicas Rack (ABS) - Sold
Only the sub frame remaining - $50ono
Series 1.5 ABS Unit
Thanks
Hi I was wondering would you have the front bumper bar.
Thanks
sorry man i woke up a bit late i work in the city monday - thursday and can pick up after 6pm any of those days, other wise friday afternoon after 2pm, let me know which is best, once again sorry :happy:
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
