hey guys selling some 17 inch drift teks
*brand new condition not 1 scratch on them
* wrapped in wenli 235/45s very gripy tires (very wide) with 99% tred
*light weight rims
*5 spoke multi-stud
*came of series 1 r33
*8.5" fronts 9.5" rear
*imacc condition onli used it for 300ks MAX only bought 1 month ago
BRAND NEW
sold my line without rims cos the guy wanted to put his 20inch ones on :)
so their siting in my garage waiting for sumone to buy them and wanna
sell them quick need to pay off debts
Price : 1500ono
pm me if interested and we can work out sumthing
cheers :D
You wouldnt be interested in good condition 32 GTR rims in sticky rubber?
Cheers
nar m8 sorry havnt got the car any more just wanna the rims out of the garage thanx n e way
I am interested in the pair of 17x9.5 if you want to separate them. What is the best price you can do on them, tires or no tires.
I can even pick them up if need be depending on which side of sydney you are on.
Can you just confirm that these are the 17x9.5 inch, +18 offset rims?
Edited by mitch_SR32
sorry mate im not parting if u want them u needa buy them
cheers
*light weight rims
*5 spoke multi-stud
BRAND NEW
Price : 1500ono
cheers :P
hey guys just found out they are 8inch at the front nd 9 inch at the rear :S
need to sell quick no stupid offers please
G'Day mate!! I'm intrested in the rims you have for sale, but was just wondering if you'll take $1000.00 cash for it (JUST A QUESTION), I'm bit strapped for $$$ being christmas and all, hows the weeekend looking? Quick sale if your intrested............ or maybe not? email me on; [email protected]
Edited by jap34
What offset are these, shoot us a text mate 0431 10 10 16. I want to see if they'll fit on a BF MKII Falcon.
What brand tyres?
JUST CLEARING UP I MADE A TYPO BEFORE
THEY ARE 8 INCH AT FRONTS AND 9 INCH AT REARS
QUICK SALE GUYS NEED THESE GONE $1400 not 1 scratch
**BRAND NEW***
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
