Ok, The long and the short of this little tale is that the head I have has a bit of a bow in it..
My machinest can straighten this, and re-cut the valves and all that other stuff,
But the question that I really need to know the answer to is how much can I safely shave off the face after all the other work is done?
its a stock RB30 bottem end, stock 25det head. Stock head gasget, stock valves, stock cams (Planning on pon cams during the year!)
I would like to raise the compression if possable, can you guys help?
https://www.sau.com.au/forums/topic/248892-head-surfacing-for-2530/
Your best bet is too get another head.
As to straighten a warped aluminium head PROPERLY will cost you more or nearly as much as to buy another. The process involves heating the head to the point where it straightens itself, or levels itself out so to speak. This in itself isnt the expensive part. You will then require to have the camsaft tunnels line bored to make sure they are straight, and more than likely the majority of valve seats replaced ( new ones pressed in ) , as they come loose due to the different expansion rates between the two different materials.
If your machinist just plans to surface it - then you consider all your optins first.
yea , I am aware of all you said. They sometimes 'pull' the lifter bores out of round and valve guides can fall out as well!
All of which I am aware of.. thanks for the heads up. Yes, he is doing all that plus a cc check, pressure check and crack test before any machining takes place..
The old owner must have had an issue, cos the deck face is flat as, but the cam journals are a bit out. We are thinking that the old engine had an issue and he just skimmed the head and away he went without checking anything else..
So the question still remains, after i get all the other stuff fixed, how much can be shaved off the face? has somebody done a valve to piston check? does someone know the answer I am after?
if it was me, i would just get one of those engine CR calulators on the net and spend an hour punching in numbers, until you get a combo that comes up with a good CR, somewhere around the 8.2-9.0 mark.
When you say stock bottom end, std pistons/rods or rebuilt? stock 86mm bore?
I'm not sure what the stock hg thickness is, but you'll need to work that out, im sure someone here will tell you.
I would just take off as little as possible from the head, just untill its level, then definately cc the head so you know how much to take off the block to get your target CR. You have much more to work with, with the block since the stock pistons sit below the top of the bore, so if any decent shaving is to be done i would be looking there, not the head.
So basically, if you want to keep this head, get it sorted with the lest possible taken off, find out how many cc's there are in each chamber, determine the hg thickness, then get on the calculator and work out how much you need to deck the block to get you CR, you might even zero deck the block..
the block has completly stock everything atm (226 000km on it! not going to refresh it), going to just run it to see how well it goes, if it works as well as I hope, I will start on 'built' engine. But this mongrel head is being a pain in the butt. If its not sorted in a few weeks I will buy another head and go nuts on it!
Thanks for the input. Got any links to a compression calculator? cheers
google.com.au :banana:
or spoolup, the person that answered in this thread has one on his website which is in his signature.
By the sounds of things, if the head has been that badly warped it would be cheaper and easier to just get another head. Goodluck with it
Edited by R34GTFOUR
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
