Means the air/fuel mixture inside the cylinder is exploding under its own free will from compression instead of burning when the engine ignites a spark from the spark plug.
Ie. your engine will eventually die if it continues like this.
Edited by PM-R33
thanks mate, so the fix is a tune. could it be because it was not tuned properly when i put in the Power FC a couple of months ago.
is the problem only happening when the light comes on during high boost or all the time?
Yep a tune will fix it. Did it get tuned when you installed it? Or are you just running it on the base map?
The light also flashes if the injectors are maxing out, or if the airflow metre is maxing out. So it could also be that.
Check your hand controller's max knock count, max airflow voltage and max injector duty cycle to see what one it is. But most likely it is knock.
Best bet just take it back to your tuner and get him to check it out. When you take it there, get the car's engine light to come on along the way but don't turn the car off when you get to him. That way he can have a look at all the max values on the hand controller and tell you straight away what's causing it. Whether its knock, the afm or injectors.
Good luck.
Edited by PM-R33
i started reading and when u didnt know wat knock was straight away i suspected u wouldnt have the correct fuel in it... i see it alot.... kinda makes me angry sumtimes lol..... if it was tuned on 98 and ur gonna go flog it sumwhere make sure it has that octane fuel in it. minimum u can run lower octane fuel if ur just lightly cruising but it still not recommended. my 2cents
yeh i no it was tuned on 98 and i'm ment to run 98, but the servo had run out. they only had 95 and i had 10 mintues to get to the crusie. what i didn't realise is the damage that could of been done while i was out with 300 other cars letting her have it for 4 hours.
well shouldnt it have clicked wen for sum reason sumthing different is happening now that ur not running the same petty(generally flashing lights mean get off the go peddle).... like seriously now. thats like puttin canola oil in ur sump and saying oh she'll love it..... sorry to rant on but sum ppl are just so ignorent.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
