Hi guys, im wrecking a 1992 R33 s1 5 speed gtst.
car has damage to the front and rear passengers quarters from someone doing a U turn infront of the previous owner
so the car is complete minus front passengers side guard and headlight, bonnet, front bar and stock intercooler
Its stock apart front having a turbo timer, 3 inch straight through cat back exhaust, 17s and lowered springs
its currently running and driving fine (had to do some funky intake piping to delete the non existant cooler), so for anyone interested in the engine or box it can be test driven
Engine has 110,000 Ks one it and has only ever seen stock boost
Gearbox was rebuilt just before the previous owner got the car and he had reciepts for it, but unfortunately didnt keep them. so the box has had around 6 months of driving on it since it was rebuilt
would like around $3200 for engine and box with all accessories and stuff to pretty much make the engine run, im negotiable on the price and whats included with it
Brakes and 5 stud stuff
Front and Rear calipers with pads and lines
front and rear rotors, measuring 29mm thick front 17mm thick rear
all drum handbrake stuff with cables
front and rear hubs
bm44 non abs master cylinder
all in good working order
$1200
wheels are WEDS brand 17x8 front and 17x9 rear with +38 offset all round. front tyres are 235 45 17s and about 80-90% tread rears are 255 40 17 and are about 90%. and the front rims are 4/5 multi stud
would ideally like to sell engine and box before i sell anything that will stop the car being driveable just incase someone really wants a test drive
Located just outside of geelong, vic
happy to post anything that australia post will take
PM or reply here with what you want or if you want more pics or anything
cheers
Nick
will get more pics of the interior and stuff tomorrow if i can find the camera
https://www.sau.com.au/forums/topic/248999-wrecking-s1-r33-gtst-5-speed-vic/
  • Replies 64
hav you sold all the plastics from the gear surround up to the top of dash? (around climate control etc)
nope, all of that is still there. was supposed to sell the gearstick surround with the full manual conversion but havnt heard back from the guy that was interested
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
