3" XFORCE cat back exhaust for sale. currently installed on my R34 GT-T
has a nice sound to it. not too loud. on idle its nice and quite cruising speed the noise is ther but not too loud and on full woot its tough as.
reason for sale is i im not a fan of the angle exhaust and want something louder and better flow so going for something custom.
these are only pics i have
looking for offer over $200 but feel free to make an offer. worst case you will get a NO answer lol but nothing silly like $50 please ;)
location is in Rowville Melbourne. exhaust is on the car so more then happy for a test listen/drive
ta
Ash
https://www.sau.com.au/forums/topic/249265-xforce-cat-back-3-exhaust/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
