  • Replies 155
Yes, you can use the wiring for the stock boost solenoid. Mine has been wired up with spade connectors straight into the stock boost solenoid plug :(
You will need to change the way the tubes to the mac valve are set up, though.
well ive only got to choose from 1 black and 1 white wire to connect the wires from the MAC valve (which both wires are black). i dont know which one to connect to which. the wiring diagram only had the colours that come from the ecu which are LG and L/W.
and i still dont know which wires from the mac valve are + and -
I just went and had a look at mine for you. Both wires on the Mac valve are black, but it looks like one has writing on it. I also saw '---', so I guess that one is the negative. The stock BC connector is a rectangle shape with the connectors in a T sort of layout. The connector that is at one end of the rectangle connector is the negative. The one that runs down the centre of the 'rectangle' is the positive. I hope that makes sense.
OK, well there ya go then. That would explain why the wires are both black :D
yeah it confused me at first.. just like injectors.. they don't have + or -
you learn something every day ;) .. dunno what i have learnt yet though :)
yeah it confused me at first.. just injectors.. they don't have + or -
you learn something every day :D .. dunno what i have learnt yet though ;)
Yes you have...
That DiRT is a tightass and wont spend coin on a wideband
Yes you have...
If i am tuning it then you are going to have to have a wideband sensor. Simple.
Anthony, get him to pull the one out of your car, then he can put it back when your done?
No.
I win. he purchased one :D I want to setup Open Loop correction on his car.. big $$ engine would be good to have some insurance when he is at power cruise
his o2 sensor is more in the front half than the rear end doof :D
Anthony would you mind PM'ing me with a basic run down of setting up antilag and cyclic idle. Did the fuel map need to be changed at all?
Edited by TiTAN
good thing I don't tune my own car then...
either way... the heart-break is still there...
hey ive tuned your car!!.. Twice! Stop your whinging!
& No can do Titan.. you got stock turbo.. i am guessing it would break on your first anti lag.
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
