I have made the decision to sell off my R32 GTR
The car does not get used much anymore and the rego is just running out without being used. With another dedicated racecar nearing completion it will be used even less next year.
The base car is a 90 model R32 GTR Originaly gunmetal grey.
Engine mods
Engine was rebuilt 2,500Km's ago.
New R33 crank shaft
- Standard bearing sizes
- Fully balanced with clutch and harmonic balancer fitted
- Grub screwed oil galleries
- Modified oil galleries (specific details available to purchaser)
Original 05u block
- Was cleaned, sonic tested, tunnel aligned and honed.
- Internal modifications to assist oil return to sump (specifics available again)
- Enlarged oil return galleries from head to sump
- Oil restrictor fitted
- Modified coolant passages
Factory R33 N1 rods
- Were from an unstarted crate engine
- Fitted with new ARP rod studs and nuts.
Factory N1 pistons
- Were all equally weighed (specific weights to purchaser)
- Fitted with new rings
- From same engine as the rods
Original Head
- Cleaned, decked valves cut and guides replaced
- New stem seals and all spring seat pressures set
- After market Graphite head gasket
- JJR adjustable cam gears and Clear cover
- Mild port work was done to the head when it was apart, nothing major but some casting irreglarities were cleaned up and was flow benched to ensure everything was even and equal.
Turbos are believed to be steel wheel direct replacements
Has an intank 040 pump fitted
Basicaly the engine was blueprinted and assembled, so squish heights etc were all checked, and machined to acheive tolerances required. Its using the same clearances as our race engines but without the exotic pistons/rods/crank etc.
The builder is more than happy to put purchasers in contact with the machinist who did all the pre assembly work to verify exactly whats in it and how it was built.
2x 3/4 inch custom made front pipes (formerly made for the race car)
90mm exhaust from cat back
Extreme heavy duty button clutch
Nismo Slave cylinder
Transfer case was repaired/overhauled 1000Km's ago
Blitz ID3 boost controller
Custom oil catch can system
Suspension- Apexi shocks and Eibach Springs
- Nismo lower rear control arms
- Nismo upper rear control arms
- Nismo Front castor rods
- Cusco upper front camber arms
- Replaced sway bar bushes and links
Its currently set-up with spring rates to suit semi slicks and does handle very nicely on the track.
The body was resprayed last year in a brilliant white. Inside and out paint job done by exclusive colours. Has a N1 rear boot lip and bonnet lip fitted.
Paint work is still immaculate
Comes with Enkei 17 by 9.5 inch rims with decent tires.
Brakes - Callipers were all overhauled with new genuine nissan seals at the beginning of 2008.
- DBA 4000 series slotted front rotors
- Unknown slotted rear rotors
- Bendix ultimate rear pads
- TRW lucas front pads
- Master cylinder recently had new seals fitted as well (mid 2008)
The interior is all in great condition but the seats have the usual bolstering wear on them.
Car recently competed in the NSW dutton rally and held its own very well without missing a beat.
Its completed in club level super sprint championship in 2008 as well as many a track days.
With a good driver it has achieved - wakefield park 1.08.20
- oran park south 49.45
- oran park GP 1.20.10
All of which were done on average Advan A048 tires.
I'm asking $20,000 for it and not open to any form of trade.
May be negotiable if it's going to a good home.
Located in Sydney
Contact 0404 832 620 After 5:30pm weekdays
Here are a few photos of it, I can provide interior and engine bay photos if serious interest is had as the car is currently in storage.
https://www.sau.com.au/forums/topic/249424-r32-gtr-white-with-mods/
It has a Apexi Power Fc
On road has never been over 1bar boost and about 280kws at the wheels
Eibach springs I can run different combos but currently it has 8 fronts and 6.5 at rears.
If you want anymore info or photos give me a call :banana:
Contact Jess or Brad 0404 832 620 After 5:30pm
Engine mods
New R33 crank shaft
Original 05u block
Factory R33 N1 rods
Factory N1 pistons
Original Head
Located in Sydney
Hi how are you? I saw this Gtr the other night and i sent you a text message the other day but i got no reply... I am wondering is this car still for sale? Could u send some pics of the interior if possible to [email protected]
Thanks :D
Sorry I dont have any pictures of the interior currently and the car is in storage.
Only interested in serious buyers if your genuine buyer wouldn't you prefer to organise an inspection?
If i had the cash i would buy it off you right now Jess.
Good luck with the sale. Thinks about selling the 34!!!
Aww and I would sell it to you cause I know it would be going to a good home!!
Cheers..I think you need a change like me :cool:
Oh ok thats cool i am genuinely interested in the car and would love to see the car its just i work 6 days a week and its hard for me to get a bit of time to myself hence why i asked if u had any interior pictures...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
