Hey guys i searched this and didn't come up with much so thought i would ask it.
On my stock GT-R turbos my car was boosted to 17psi from the actuators but now i did the N1 Conversion its running at 6psi from the actuator.
What do i have to do to get it back to 17psi? I don't understand how this works so if there anyone who knows could they school me and tell me how to get it back to 17 so ill know for the future. thanks
never done it on a car, only on other things so i guess its the same,
when you close the actuator (if its the same one we're talking about) it routes more air through the turbo, so just close it and that will see a bit over 17psi, not sure how much.
please. feel free to correct me
some actuators have a thread on the rod that goes the wastegate... u can disconect the rod fromt he wastgate (its only a split pin) and turn the rod...if you make the rod shorter it will increase boost, longer decrease boost... i dont know however if gtr turbos have this and if they did how youd go about setting both the gates to exactly the same boost...
thats why im stuck see i hat a t piece before and i recently had a avcr which i sold i needed the cash. But when i got the car back from my rebuild it was running 17psi he said boosted from the actuators so now that i have n1's its on 6 psi and it really sucks .
Sounds like you and him (mechanic) might be mixing things up between yourselves maybe. When he said its making 17psi from the actuator maybe he just meant the avcr isnt opening the actuators til 17psi. Would make sense if you had it t-pieced and the actuator control unit installed. You also said you had sold the avcr so now you have nothing but standard actuators explaining the low boost. I think the obvious answer is your going to need another boost control unit so get more out of the N1 turbo's and control when the actuators are opening.
From the info you have given I can't see any other explanation but maybe someone else can... My mate has a 33 GTR and an old school avcr and the 2 actuators are t-pieced in and run as a single line to the avcr.
If it was running 17psi without the avcr then i dont know lol.. f**ked actuators on your stock turbo's maybe or dodgy internal gates?? I had a stuffed actuator (single RB25DET turbo and actuator on an RB20DET) and it was running/spiking 14psi and holding 12 when it was supposed to run 6psi.
Edited by FordyR31
If the old actuators were adjustable and set to 17 psi then you should be able to swap them with the n1 actuators. Measure the length of them first before you do this though to check that it will work on n1's.
Otherwise buy a new boost controller. Would be easier.
Or if you want a free mod to up the boost...get some pliers and bend the actuator rods so that they have shorter throw :worship:
Or if you want a free mod to up the boost...get some pliers and bend the actuator rods so that they have shorter throw :down:
ah ok yea now i get it thanks man the guy above obviously didn't understand what i said and posted anyway!
I never installed the AVC-R!!!!!!!!!!!!!!!!!!!!!!!!!!!1
The car was previously running 17 psi set from the actuators i was going to install an avcr but i didnt do it!!!!!
thanx man ill do what you said and see how i go
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
