Hey guys i searched this and didn't come up with much so thought i would ask it.
On my stock GT-R turbos my car was boosted to 17psi from the actuators but now i did the N1 Conversion its running at 6psi from the actuator.
What do i have to do to get it back to 17psi? I don't understand how this works so if there anyone who knows could they school me and tell me how to get it back to 17 so ill know for the future. thanks
never done it on a car, only on other things so i guess its the same,
when you close the actuator (if its the same one we're talking about) it routes more air through the turbo, so just close it and that will see a bit over 17psi, not sure how much.
please. feel free to correct me
some actuators have a thread on the rod that goes the wastegate... u can disconect the rod fromt he wastgate (its only a split pin) and turn the rod...if you make the rod shorter it will increase boost, longer decrease boost... i dont know however if gtr turbos have this and if they did how youd go about setting both the gates to exactly the same boost...
thats why im stuck see i hat a t piece before and i recently had a avcr which i sold i needed the cash. But when i got the car back from my rebuild it was running 17psi he said boosted from the actuators so now that i have n1's its on 6 psi and it really sucks .
Sounds like you and him (mechanic) might be mixing things up between yourselves maybe. When he said its making 17psi from the actuator maybe he just meant the avcr isnt opening the actuators til 17psi. Would make sense if you had it t-pieced and the actuator control unit installed. You also said you had sold the avcr so now you have nothing but standard actuators explaining the low boost. I think the obvious answer is your going to need another boost control unit so get more out of the N1 turbo's and control when the actuators are opening.
From the info you have given I can't see any other explanation but maybe someone else can... My mate has a 33 GTR and an old school avcr and the 2 actuators are t-pieced in and run as a single line to the avcr.
If it was running 17psi without the avcr then i dont know lol.. f**ked actuators on your stock turbo's maybe or dodgy internal gates?? I had a stuffed actuator (single RB25DET turbo and actuator on an RB20DET) and it was running/spiking 14psi and holding 12 when it was supposed to run 6psi.
Edited by FordyR31
If the old actuators were adjustable and set to 17 psi then you should be able to swap them with the n1 actuators. Measure the length of them first before you do this though to check that it will work on n1's.
Otherwise buy a new boost controller. Would be easier.
Or if you want a free mod to up the boost...get some pliers and bend the actuator rods so that they have shorter throw :worship:
Or if you want a free mod to up the boost...get some pliers and bend the actuator rods so that they have shorter throw :down:
ah ok yea now i get it thanks man the guy above obviously didn't understand what i said and posted anyway!
I never installed the AVC-R!!!!!!!!!!!!!!!!!!!!!!!!!!!1
The car was previously running 17 psi set from the actuators i was going to install an avcr but i didnt do it!!!!!
thanx man ill do what you said and see how i go
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
