  • Replies 85
edit---TODAY--i was down at welshpool (getting my licence re-newed, no yellow sticker) there was stuff all cars there, a disgusting red celica with huge chromies, and a pig s13.
THOUGH i went in n came out in 30mins and the line hadnt moved at all. that was around, 2pm
Edited by Char
https://www.sau.com.au/forums/topic/249806-pits/page/3/#findComment-4333523
how did you go ricca, no luck for me. got to see if my brides are adr approved, my park light reflector has to be secured, high level stop light, need tyre plark. car re weight. need to have proof that the car doesnt come with a air bag. high beams. (they worked before i left to go) got to fill out this mod form and send it through and prob have to get a engineer to look at it.
https://www.sau.com.au/forums/topic/249806-pits/page/3/#findComment-4334598
sorry if i am jacking this thread, but how am i meant to prove that my car doesnt come with air bags
the easiest way to prove you dont have airbags is to look at your dash lights. If you have an airbag, upon igntion of the car, the airbag light will come on for a brief few seconds as a self check. If there is no airbag light at all on the dash...the car never came with it.
Edited by ZXY
https://www.sau.com.au/forums/topic/249806-pits/page/3/#findComment-4335789
mmm when i got a yellow and went to the pits i went to the gosnells one *i had a yelloow for a T wing* i got this guy with like skin disorder and he raped me :? saying my suspension is wayyy too hard and couple of other stpuid stuff so i got my mom to take my car over at welshpool and it was done in less then 10 secs :) so yeah if i was to get a yellow again ill get my parents to take car over LOL
https://www.sau.com.au/forums/topic/249806-pits/page/3/#findComment-4336067
Well thought i give an update.
I have since my last Check installed a new
Immboiser!!
inner toe arm
fixed the Suspension
and made a bracket for the Zaust
Heading over the pits on Monday not sure where yet i have got a friend which is a Engineer and getting his Cert to Clear his own cars
he would be taking it down so he can talk the talk!!
So hope all goes well!
https://www.sau.com.au/forums/topic/249806-pits/page/3/#findComment-4352960
where would the engine number be on the 26, the inspector couldnt find it cause he said the turbos are in the way
Exactly where he's looking. There's a little bit of the block that sticks out, on the passenger side, up against where the gearbox bellhousing bolts onto the block.
He might need to use his little bendy mirror and get at it from the underside..
https://www.sau.com.au/forums/topic/249806-pits/page/3/#findComment-4354713
actually found the engine number, i guess on a 26 its different, its directly under the top radiator hose on the block
lol fair enough, they probably moved it after they realised they'd put a bunch of turbos and stuff in the way :)
https://www.sau.com.au/forums/topic/249806-pits/page/3/#findComment-4355601
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
