Hello all.
I've have a question about RB31DET's.
What makes them 31's, different from the 30's?
I have a series 2 N/A RB30 that I'm bolting a RB26 head to & putting it in my Z32. I'm going to be using forged pistons antway & was wondering if the RB31 is just a overbored RB30. I've been searching around on here & the interweb but can't find the info on what makes a RB31 a RB31.
Any replys would be graetfully received.
Thanks
Stu.
https://www.sau.com.au/forums/topic/250210-rb31det/
Thanks for the info guys.
87mm bore with stock stroke is only 3032cc, your far better to keep the bore as thick as possible and if you want a RB31 or bigger go with a stroker crank with custom pistons and rods etc.
Not worth the trouble/expense unless your after something different and even more torque than a 30.
A well built 30 is usually plenty in any case.
Rob
https://www.sau.com.au/forums/topic/250210-rb31det/#findComment-4340351
Hi Rob
Since no one has asked the question I will.
What does one of your RB33 stroker kits cost ? and what does it consist of ?
I am just curious as are a few on these forums.
Cheers
Rob
Edited by Spoolup
https://www.sau.com.au/forums/topic/250210-rb31det/#findComment-4340880
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
