I have just installed a turbo into a GTS and have a few problems I thought you guys could shed some light on. The best way I can describe the problems is when it boosts from about 5psi up it starts to miss, but it only happens in third gear and over, and from about 3000 rpm and up. When the gas is let off the blow off valve does not release the pressure equally, it sort of flutters and the boost gauge jumps up and down rapidly in time with the fluttering. The parts that I got with the turbo are a GTST AAC valve and the o2 sensor. Do I need a GTST afm as well? Any info you guys can provide would be greatly appreciated. Thanks.
https://www.sau.com.au/forums/topic/25025-turbo-problems-rb20de/
You don't need a GTSt AFM. Make sure you have the DET injectors and make sure you have spark-plugs to suit a GTSt. Remember you make more boost in thrid gear than you do in 1st or 2nd so you should make sure your timing etc is done to accomodate the extra load in the higher gears.
And if anyone tells you that you can't turbo the NA tell them to bite your ass because I did it over a year ago and that car has since been sold twice and is still a rocket.
Running 9~10psi of boost is no problem, I even ran the stock intercooler, it's all in the tuning. I ran the NA computer for a while too as it runs CRAZY rich to keep the engine alive long enough to get it sorted.
Remember there are two ways to turbocharge...
Low compression High Boost
High compression Low Boost
The first is good for top end, the latter for mid range punch, which is why my 32 was so quick on the street.
Tuning, Tuning, Tuning. That's the key.
Little steps at a time.
Well got my car back today unchanged, the guy said its nothing to do with the timing but it looks to be an air/fuel problem. He ran out of time to do anything about it today. On Monday he's going to do tests and stuff with his oscilloscope. I just nodded a said OK as if I knew what he was talking about.
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
