hello
well i will be undertaking a welding course in February, and currently have a project 31 so i thought having a welder would be a handy thing to have for those little fabrication jobs that come up with DIY projects. I have a little bit of MIG and stick experience but as far as welding intercooler piping, exhausts and all that sort of stuff, i figure having a TIG would be most beneficial.
There are shitloads of second hand welders for sale in the local trader, so what kind of brands should i look for, with what kind of features? i dont want to spend more the 1k either
preferably less than that if possible!
cheers
https://www.sau.com.au/forums/topic/250299-tig-welder/
for that kind of price range, i cant really suggest anything.
Might be better if you list what there is available, since most TIG machines are $4K+.
all you really need for alloy is it capable of AC welding, and about 120Amps- but you might be fighting the machinea bit to get good.
https://www.sau.com.au/forums/topic/250299-tig-welder/#findComment-4337447
yer like i said im pretty much after brands and functions as there are heaps for sale second hand below 1k.....just a shitload of different brands etc etc
https://www.sau.com.au/forums/topic/250299-tig-welder/#findComment-4337874
if you can handle not being able to weld Alu you should be able to get something. i've got a $400 Arc welder that i've got a tig torch/gas for etc, will be fine for most stuff. i dont rkn you really need a big $4k machine for the basic stuf you've listed
https://www.sau.com.au/forums/topic/250299-tig-welder/#findComment-4337946
Hey mate if your not going to use it much just get a cheap one off ebay, look for the duty cycle at min 50% and high frequency start up, and you would want an inverter model much nicer on 240 volt oh and a foot controler ( controls your amps like a throtle)
My mate got a cheap one and its not to bad really if your new at the game you would love it from memory he paid under a grand,
like what was said before if you want something nice your looking at 4k up my kemmpi cost just under 5k and is f*ckin great but thats what i do for a livin, one more thing if you can find one with a pulse on it even better good luck buddy :P
https://www.sau.com.au/forums/topic/250299-tig-welder/#findComment-4346148
    • I might just check it out.. A Q among all those skylines.. lol
    • Time will tell, they're doing all the admin stuff at the moment. I've submitted all the required details, photos, etc.   I was under the impression that DC coupling is the best approach, i.e.: Solar Array -> Battery Invertor -> Battery  Where as AC Coupling is simpler, however less efficient, i.e.: Solar Array -> Solar Invertor -> Battery Invertor -> Battery
    • The price is really great for that kind of capacity. I thought similar setups cost way more. How's your efficiency been with the DC-coupling? I've heard sometimes there can be a bit of a performance loss.
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
