TOPGEAR PHOTOGRAPHY’S CITY BEACH & BAY CRUISE
Hot or not - Modified to stock Bring it out & have a killa day in the sun!
Last year at the city, beach and bay we had over 80 cars, Filled every carpark to the brim and had a damn good time. SMS Everyone you know this time and lets push for over 100 cars! photos can be seen at www.topgearphotography.net!
When : January 17th, 3rd Saturday of the month
Where : K-Mart Anzac highway, Rear Carpark.
Meet / Leave times : Meet at 12lunch for a 1pm Leave - SHARP Destinations : Moana Esplanade, West Beach Skate Park, Semaphore Esplanade - With a pub meal afterwards at the Largs Peer hotel.
If theres any further questions, please feel free to call Scotty on : 0433 805 514. Further Info can be found at www.topgearphotography.net
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
