Item: Complete Rb26 Bottom end including sump if needed. (from R32)
Age: Most parts Brand new, crank used but crack tested.
Condition: All new parts with machining done (Almost at the stage of final assembly)
Price: Complete sell for $6000firm Note: value well over $7000
Willing to separate tho would rather sell together considering the work thats been done.
Value:
Cp pistons are +20 thou, well over $1000 new
Brand new Eagle rods $500+
N1 block is brand new item with machining, $2400 + machining work
Used tested cran $1000
acl bearings & arp main studs $200+
Rb26 sump + diff $500
+ the machining work $$$$
Comments:
Machining done as follows,
Hot tank Crank, Crack test crank,
Studs nuts fitted to main caps, Line hone 7 main's,
Rod check/set hone small end, rod check big end and align.
Tunnels measure sizes measure crush, check & set bearing clearances
Drill tap fit Plug
Comp spec micro polish crankshaft
Bore and Hone 6 cyl Torque plate
Trial build check deck and square
reface block square.
Balance 6 cyl manual.
Reason for sale, going to use my Mahle/Pauter rod combo instead
Edited by Angus Smart
Bump,
Would like to add all the work has been carried out by a very good shop in Adelaide Pm me if your interested to find out who.
good luck with that one buddy...
I've just checked the crank, dew to a few questions. it is the larger sized crank drive.
Cp pistons are 86.5mm (+20thou)
and going on what i can see, the ring gaps are the only thing left to be done +final assembly
Pistons and Rods are sold and there is no arp studs left
the rest is still up for sale
Block/Cradle, crank and bearings. will take 3400 for block and crank,
photos of block etc..
Rods and pistons sold to me! Thanks Andrew!!!!
Andrew is a great guy to deal with guys!
Free bump!
Block. crank cradle bearings still available.
Crank was rebuild/checked by Crankshaft rebuilders in Sa or Victoria.
U willing to sell the cradle seperate if so message me. Cheers
  • 1 year later...
i'm new to the forums so i can't send PMs yet.. do you have an e_mail where i can contact you?
i'm interested in the bearings
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
