  • Replies 69
**Also had a few PM's regarding FMIC, Sorry Guys but it's only going to be sold complete (Core & Piping) & is still For Sale :banana:
Will post up pics of the Boost Controller & BOV/Adapter Plate too this afternoon :ermm:
Still got:
Bootlid
S2 Spoiler
Bonnet
Front Fender's
Door's
All Window's
Mirrors
FMIC with Piping
Complete Interior except Driver's Seat & Dash Cluster
Tail Lights
Rear Skyline Garnish
Rear Bar
Exhaust
Greddy Boost Controller
BLITZ BOV with Adapter Plate
If not listed PM me :(
I'm chasing the air con fan (sits in front of the radiator), and the passenger mirror bracket (not the mirror itself).
I've got the aircon fan & i will check the bracket, the mirror is still there so it should be there. I'll PM you anyway.
Hey mate,
when is the next time available to come pick-up the steering wheel?
Finally figured it out
Regards, Sean
:laugh: I was waiting to hear back from you, thought you'd forgotten about it, would the weekend be ok?? message me anytime & we'll work out a time!
Got rear handbrake assembly / cables? What about front and rear hubs??
I do but it's still on the Car...
