hey all,
so ive just had the full garrett treatment; 2860-5, 115mm FMIC+ pipping, LINK G4, 770 inj, profect b, hks twin, nismo pump, standard mint engine running 18 lbs, 7500RPM limit, 320AWKW......
i dont want to have to go through the whole forged rebuild yet, but will eventually, i am really only using this car for street, and am guessing if i start winding these buggers up to around the 380+awkw its going to put a strain on the rest of the car
QUESTIONS
i think i would like to trade down to the smaller -7's
i miss the big kick of the smaller turbos, im not after massive power
1. so the -7's are maxed at around 330awkw, what kind of boost is needed for this figure?
2. are cams needed?
3. has anyone driven same car, but with the different turbos, is there quite a big difference?
4. am i stupid? i kinda was given wrong advice on turbo sizing
5. have tryed searching but it aint working
cheers robbie
https://www.sau.com.au/forums/topic/250659-2860-help-please/
Read this thread:
http://www.gtr.co.uk/forum/99765-gt-ss-gt2530.html
2530s are similar to what you have -5. A good tuner will get similar response out of -5 to the -7 (only 500rpm difference) but with more power from 5000rpm onwards.
There are some in the thread that started with the -7 and went to the -5. They say they prefer the -5 set up.
Id be listening to people who have had both set ups, but thats just me.
Heres a link to GTSS vs -5 done on the same car on the same dyno if that helps.
http://sthitec.blogspot.com/2008/05/gt-ss-...or-2560r-5.html
The setup of the -5's it's bundled off with the 0.64 AR rear as opposed to the smaller hot side on the -7's , so at 250rwkw plus it's got an easier path to push the compressor to it's potential.
The -7's at 330rwkw are going to need lots of boost and due to the efficiency range will be pumping much hotter air than the -5's or -9's.
The -9's are better than -7's and if setup correctly will get you the same power you have now (320rwkw) with 1,000 rpm or more of earlier spool and a larger amount of power in the lower / mid part of the power band.
The key factor in getting the turbos to do what you want is to set them up correctly. The -9's are very tune forgiving and this is clear from the compressor map.
I reckon -9's with a larger 0.84 housing (and custom dumps to suit) would be the ultimate with a serious build/cams.
hmmm, maybe i should just increase the boost to 20lbs, and see how they feel then, dont get me wrong its a sweet car to drive, but miss the ol' "chuck back into seat"
At 320rwkw you should be thrown back alot more than the stock turbo's.
You could tune the bottom end power band with adjustable cam gears and lop off the top end power to keep the stock motor alive.
It will be a nice suprise for your tuner to be one of the few people who walk in and say " up the boost to 20lbs we are aiming for the best mid range and I want to limit the top end to 300rwkw and 7000 rpm ".
My rb26 has the 2860 -7 and is making 300rwkw at 16psi it fairly throws me back into the seat... was enough for a passenger to bend the support for the backrest lol. i'm thinking about winding them up to 18-19psi and going for 330-340rwkw with a more aggressive tune.
that's what i did with the 33
hks 2835 pro s on stock rb25 with adj ex cam gear
i'm gettin 265 where most people are gettin 280 BUT i have stock turbo response and couldn't be happier
yeah i get full boost by about 3200 - 3500 and with the bottom end of a 26 it's not too worrying to have it alitlle later at least you can drive off boost around town easier but it's still super responsive and doesn't stop pulling till the rev limiter.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
