I have been thinking which cams to run in my RB30/RB26 setup.. after reading lots of post I was thinking that the Tomei poncams.. 264 duration with 9.15 lift was the best option? The other otpion would be HKS Step ones which are 264 with only 8.7lift.. What would be the difference in drivability and power output with each of these setups?
I am running a stock bottom end and will limit the rpm to around 6750. maybe 7000rpm max. Will have the rods peened so trying to determine the max boost I can run at the mo relatively safely!? I reckon about 1.4bar? I am hoping to get around 550bhp plus at the flywheel with the corect supporting mods and turbo.
I have just had the offer of a pair of HKS cams.. they are both step1 but one is a 264 and one is a 272?
How will this set up work. does it matter which cam has the longer duration?
What should I do!!
Thanks
Lee
https://www.sau.com.au/forums/topic/250808-hks-step-1s-of-poncams-rb30rb26/
Hey there,
I will be running a big single! Main thing is I wil be limited on boost and rpm by the fact I have a stock bottom end.. so reckon max 20psi and 7000rpm.. although I'll probably run more like 17psi and 6750 rpm to be safe!
Cheers
Lee
Adriano,
Are yours the step 2 hks? So you have uprated springs as well.. Would you suggest sticking with stock cams or holding out for some tomei's?
I can get the cams with pullies or £250. New I think they are about £260 each plus shipping! I thought that was pretty good!
I am planning to run either a Master Power or a Holset.. More chance it will be a Holset at the mo.. So it's a little bit experimental! So you reckon i'll make the power on lower boost? Surely that woul dbe better for the engine?
Cheers
Lee
Has anybody cam doctored any of name brand Cams. I think for the RB30/26 you could probably get away with aggressive ramps as the rev limit is 1000rpm lower than most rb26. I would like to know who has the greatest area under the curve for the same advertised duration.
  • 2 months later...
Adriano,
where are u getting these prices if u dont mind me asking? im also looking at possibly upgrading my cams
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
