so many now in Dubai hey - they look best in black imo. i saw one black with painted black rims and it looked nice and tough - much nicer in the flesh...looks like a space ship - the only problem is when parked next to Zondas, Veyrons, Koeniggseggs etc they tend to lose a bit of their flair...
  • 8 months later...
Titanium grey? R35 GTR at Merdian sport today, had a quick chat to the owner, he said he used to own an R32gtr when they first come out in Australia :bunny: ....but then all he owns is Porka 911, GT3......
His car is getting Racing Harness install, said he was racing in PI in his GT3 and thing go sideway too much, gave him the shit so he bought an R35 GTR :) !
Noice.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
