  • Replies 70
Posted Images
China/Jap/Brand/NoName?
depends dude, how much you want to pay and do you have a budget and what do you want to do in the future?
you have a workshop carrying out your work, that's why they're there, ask them dude they'll give you great advice
https://www.sau.com.au/forums/topic/251396-heyy/#findComment-4351974
he told me 2 grand thats why im still lookin around
https://www.sau.com.au/forums/topic/251396-heyy/#findComment-4351986
heyy i got my car dyno last week all i got is a 3inch cat bak zorst pod and 12 psi
how much power do you want?
- Finish exhaust (dump pipe and front pipe) + remove cat or buy highflow cat
- FMIC kit
- safc or similar (depends how much u want to spend, cheap go piggyback aka safc, lots go full aftermarket $$$ or ROM-tune of stock ecu)
- fuel pump (really only needed if yours is old and not working the best)
- Rb25 turbo
then retune, the rb25 turbo will give you relatively good power without too much lag.
to reduce cost fit the items yourself, to help keep cost down you can buy china brand fmic, exhaust parts the difference between china and brand name is relatively small in those parts
enjoy and drive safe
https://www.sau.com.au/forums/topic/251396-heyy/#findComment-4351993
- FMIC kit
- Rb25 turbo
my goal is around 260 hp atw
https://www.sau.com.au/forums/topic/251396-heyy/#findComment-4352000
the rb25 turbo should get you close to that, and is the best price turbo to get you around that power ($200-$500), or else you could look at something like a hks gt2510 or gt2530
give this topic a read
http://www.skylinesaustralia.com/forums/Rb...no-t103095.html
mods + power for rb20det should give u a fair idea what you can make with that mods
Edited by [Michael]
https://www.sau.com.au/forums/topic/251396-heyy/#findComment-4352008
thanks for ur help bro my goal is too hav a low 13 sec street car
https://www.sau.com.au/forums/topic/251396-heyy/#findComment-4352012
i don't think 260hp atw will achieve low 13's? aim for 300hp maybe?
get Vi-Pec ECU, 650cc injectors (sorry was thinking of RB25) maybe go a bit smaller?, 040/044, FMIC and a turbo upgrade... all the basic bolts on and you should achieve 300hp i would say
estimate though of course, and with a really good tune... with those mods you'll push a fair bit more than 12psi safely to help you get more than the 260 you're expecting
Edited by hoony
https://www.sau.com.au/forums/topic/251396-heyy/#findComment-4352031
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
