i don't think 260hp atw will achieve low 13's? aim for 300hp maybe?
get Vi-Pec ECU, 650cc injectors (sorry was thinking of RB25) maybe go a bit smaller?, 040/044, FMIC and a turbo upgrade... all the basic bolts on and you should achieve 300hp i would say
estimate though of course, and with a really good tune... with those mods you'll push a fair bit more than 12psi safely to help you get more than the 260 you're expecting
thanks for the help just hav too work out a budget new couple of weeks im gettin frnt mount 044 fuel pump fuel reg
https://www.sau.com.au/forums/topic/251396-heyy/page/2/#findComment-4352041
  • Replies 70
Posted Images
650cc injectors?
you will piss 300rwhp in on stock injectors.
i'd be going with what michael said first, safc, 25 turbo.. etc.. then see how you go. can always sell the safc/turbo for pretty much what it cost you and upgrade if/when you want more power.
https://www.sau.com.au/forums/topic/251396-heyy/page/2/#findComment-4352048
people have done mid to low 13's with 250rwhp
+1 r32 is lighter than the r33/34 so you dont need as much power
i ran 13.0 with 300ish rwhp (top end speed was good for a mid 12's 112mph) so my advice would start at 250rwhp and see where that takes you, remember practice makes perfect and dont expect to be super fast at the drags your 1st time :laugh:
edit: beaten by mitchy_
Edited by [Michael]
https://www.sau.com.au/forums/topic/251396-heyy/page/2/#findComment-4352049
i ran 13.0 with 300ish rwhp (top end speed was good for a mid 12's 112mph) so my advice would start at 250rwhp and see where that takes you, remember practice makes perfect and dont expect to be super fast at the drags your 1st time :P
thank for ur help micheal i got a qoute today for a x force turbo bak zorst for 1450 is that a good and wat sore of power would i get
https://www.sau.com.au/forums/topic/251396-heyy/page/2/#findComment-4352744
hrmm Not saying thats bad but its alot i paid
under 1k for a turbo back 3" custom Zaust from my mate i could ask if you isnt busy to make you one all you need to get it the high Flow cat (or decat) and Muffler (cannon)
https://www.sau.com.au/forums/topic/251396-heyy/page/2/#findComment-4352754
thats would be good bro maybe ill buy the dump pipe and hight flow cat how much am i lookin at payin
https://www.sau.com.au/forums/topic/251396-heyy/page/2/#findComment-4352789
go to justjap.com have a look at what styles / prices
if not call them they are nice people you would be looking at like 100 - 250 for the Dump pipe DEPENDS which one u like / wants.
High flow cat is around 175 + / or decat is free :P ha
then not to sure about sending it over its not to much!
https://www.sau.com.au/forums/topic/251396-heyy/page/2/#findComment-4352859
Anything can happen on the track its a different surface comes down to practise and time / driver! so you can have 250 hp and still run 14 /15s
best guess is to try for yuorself, its hard to judge
yeah i kne but very soon im gunna take it down hehe i got stock susp jus hav too give my car a serv and stuff
https://www.sau.com.au/forums/topic/251396-heyy/page/2/#findComment-4352959
Should be all good i still need to head down want to see what mine is running as it is stock still
got
FMIC
Custom straight turbo back Zaust
pod
JIC Coilovers
and other bits
hopefully get in the 13's
then need get a tune and see how it goes!
https://www.sau.com.au/forums/topic/251396-heyy/page/2/#findComment-4352973
this is very true
went down last week to the drags and there was a guy in a 2JZ Supra TT running 17s????? :P
https://www.sau.com.au/forums/topic/251396-heyy/page/2/#findComment-4352982
17's!!! unless he had no legs or it was a N/A with bagdes hahaha
wow
it had a fmic on it and his number plates we 2JZ but i dont know, there was no bov and those things weight a fair bit but it was only on par with v6 commonwhores. We thought he was just a tool who had put badges on and bolted a FMIC in to look "cool"
https://www.sau.com.au/forums/topic/251396-heyy/page/2/#findComment-4353018
how will i find him bro
https://www.sau.com.au/forums/topic/251396-heyy/page/2/#findComment-4353025
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
