  • Replies 70
Posted Images
it had a fmic on it and his number plates we 2JZ but i dont know, there was no bov and those things weight a fair bit but it was only on par with v6 commonwhores. We thought he was just a tool who had put badges on and bolted a FMIC in to look "cool"
A mate of mine has a 2JZGTE JZA80, with slicks and NOTHING ELSE DONE TO IT, it ran a 12.7 obviously with lots of practice :) We did have a sneaking suspicion that it came from Japan with highflowed turbos :( made 310rwhp off the boat!
Edited by bubba
https://www.sau.com.au/forums/topic/251396-heyy/page/3/#findComment-4353318
thank for ur help micheal i got a qoute today for a x force turbo bak zorst for 1450 is that a good and wat sore of power would i get
that is about correct, did it inc the cost of installing the exhaust?
because you already have a cat-back your better off just buying a front pipe and dump pipe as it will be alot cheaper (the cat-back section is the most $$ part of the exhaust)
here are few examples of what you could get and the cost
Stainless Split Dump/Front Pipes - RB20/RB25 - $269.00
Product Information
- Manufactured from high grade Stainless Steel pipe
- Stainless Flanges used at both ends (8mm Turbine outlet flange - 6mm Cat flange)
- 2.3mm wall thickness - 3 inch main pipe diameter
- Specially designed moon shaped wastegate divider
- Uninterupted exhaust gas flow through seperate of turbine exhaust and wastegate gases
- Factory 02 sensor screws straight in
- Guaranteed performance
- Guaranteed fitment
- Impeccable weld quality
- 12 month warranty
Link: http://www.skylinesaustralia.com/forums/St...on-t155238.html
Cooling-Pro Intercooler Kits - From $399.00!
COOLING-PRO INTERCOOLER KIT CONTENTS:
- Cooling-Pro Bar and Plate core, measuring 600 x 300 x 76mm
- Super strength JJR silicon joiners
- Race quality stainless hose clamps
- Mounting brackets, nuts & bolts (Where required)
LINK:http://www.skylinesaustralia.com/forums/Cooling-Pro-Intercooler-K-t138738.html
I just had a quick look and found those 2 items; but there is alot more stuff out their if you take the time to look. most of it can be bought from over-east and will be cheaper than buying it from a shop in W.A.
https://www.sau.com.au/forums/topic/251396-heyy/page/3/#findComment-4353410
I'm not going down again until the new turbo is on, I only went down last time to benchmark the mph which is why I didn't beat up on it trying to get a perfect launch/better time..
I'm more about going sideways than fast in a straight line heh
https://www.sau.com.au/forums/topic/251396-heyy/page/3/#findComment-4357460
has not been confirmed yet as getting numbers but i think they said sometime March or that could be when Drift pract at barbs Starts ha.
Will keep you posted :)
next couple of weeks im talin mine down who wants too come down and some time when i lauch it tramps is that normal
https://www.sau.com.au/forums/topic/251396-heyy/page/3/#findComment-4357726
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
