  • Replies 70
Posted Images
it had a fmic on it and his number plates we 2JZ but i dont know, there was no bov and those things weight a fair bit but it was only on par with v6 commonwhores. We thought he was just a tool who had put badges on and bolted a FMIC in to look "cool"
A mate of mine has a 2JZGTE JZA80, with slicks and NOTHING ELSE DONE TO IT, it ran a 12.7 obviously with lots of practice :) We did have a sneaking suspicion that it came from Japan with highflowed turbos :( made 310rwhp off the boat!
Edited by bubba
https://www.sau.com.au/forums/topic/251396-heyy/page/3/#findComment-4353318
thank for ur help micheal i got a qoute today for a x force turbo bak zorst for 1450 is that a good and wat sore of power would i get
that is about correct, did it inc the cost of installing the exhaust?
because you already have a cat-back your better off just buying a front pipe and dump pipe as it will be alot cheaper (the cat-back section is the most $$ part of the exhaust)
here are few examples of what you could get and the cost
Stainless Split Dump/Front Pipes - RB20/RB25 - $269.00
Product Information
- Manufactured from high grade Stainless Steel pipe
- Stainless Flanges used at both ends (8mm Turbine outlet flange - 6mm Cat flange)
- 2.3mm wall thickness - 3 inch main pipe diameter
- Specially designed moon shaped wastegate divider
- Uninterupted exhaust gas flow through seperate of turbine exhaust and wastegate gases
- Factory 02 sensor screws straight in
- Guaranteed performance
- Guaranteed fitment
- Impeccable weld quality
- 12 month warranty
Link: http://www.skylinesaustralia.com/forums/St...on-t155238.html
Cooling-Pro Intercooler Kits - From $399.00!
COOLING-PRO INTERCOOLER KIT CONTENTS:
- Cooling-Pro Bar and Plate core, measuring 600 x 300 x 76mm
- Super strength JJR silicon joiners
- Race quality stainless hose clamps
- Mounting brackets, nuts & bolts (Where required)
LINK:http://www.skylinesaustralia.com/forums/Cooling-Pro-Intercooler-K-t138738.html
I just had a quick look and found those 2 items; but there is alot more stuff out their if you take the time to look. most of it can be bought from over-east and will be cheaper than buying it from a shop in W.A.
https://www.sau.com.au/forums/topic/251396-heyy/page/3/#findComment-4353410
I'm not going down again until the new turbo is on, I only went down last time to benchmark the mph which is why I didn't beat up on it trying to get a perfect launch/better time..
I'm more about going sideways than fast in a straight line heh
https://www.sau.com.au/forums/topic/251396-heyy/page/3/#findComment-4357460
has not been confirmed yet as getting numbers but i think they said sometime March or that could be when Drift pract at barbs Starts ha.
Will keep you posted :)
next couple of weeks im talin mine down who wants too come down and some time when i lauch it tramps is that normal
https://www.sau.com.au/forums/topic/251396-heyy/page/3/#findComment-4357726
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
