Heyy
lorenzo1985
 Share
  • Replies 70
Posted Images
it had a fmic on it and his number plates we 2JZ but i dont know, there was no bov and those things weight a fair bit but it was only on par with v6 commonwhores. We thought he was just a tool who had put badges on and bolted a FMIC in to look "cool"
A mate of mine has a 2JZGTE JZA80, with slicks and NOTHING ELSE DONE TO IT, it ran a 12.7 obviously with lots of practice :) We did have a sneaking suspicion that it came from Japan with highflowed turbos :( made 310rwhp off the boat!
Edited by bubba
thank for ur help micheal i got a qoute today for a x force turbo bak zorst for 1450 is that a good and wat sore of power would i get
that is about correct, did it inc the cost of installing the exhaust?
because you already have a cat-back your better off just buying a front pipe and dump pipe as it will be alot cheaper (the cat-back section is the most $$ part of the exhaust)
here are few examples of what you could get and the cost
Stainless Split Dump/Front Pipes - RB20/RB25 - $269.00
Product Information
- Manufactured from high grade Stainless Steel pipe
- Stainless Flanges used at both ends (8mm Turbine outlet flange - 6mm Cat flange)
- 2.3mm wall thickness - 3 inch main pipe diameter
- Specially designed moon shaped wastegate divider
- Uninterupted exhaust gas flow through seperate of turbine exhaust and wastegate gases
- Factory 02 sensor screws straight in
- Guaranteed performance
- Guaranteed fitment
- Impeccable weld quality
- 12 month warranty
Link: http://www.skylinesaustralia.com/forums/St...on-t155238.html
Cooling-Pro Intercooler Kits - From $399.00!
COOLING-PRO INTERCOOLER KIT CONTENTS:
- Cooling-Pro Bar and Plate core, measuring 600 x 300 x 76mm
- Super strength JJR silicon joiners
- Race quality stainless hose clamps
- Mounting brackets, nuts & bolts (Where required)
LINK:http://www.skylinesaustralia.com/forums/Cooling-Pro-Intercooler-K-t138738.html
I just had a quick look and found those 2 items; but there is alot more stuff out their if you take the time to look. most of it can be bought from over-east and will be cheaper than buying it from a shop in W.A.
I'm not going down again until the new turbo is on, I only went down last time to benchmark the mph which is why I didn't beat up on it trying to get a perfect launch/better time..
I'm more about going sideways than fast in a straight line heh
has not been confirmed yet as getting numbers but i think they said sometime March or that could be when Drift pract at barbs Starts ha.
Will keep you posted :D
Will keep you posted :)
next couple of weeks im talin mine down who wants too come down and some time when i lauch it tramps is that normal
 Share
