Hey,
Another problem with my car and hopefully someone can answer my questions :P
Basically my car was making some loud clunking noises when driving. After taking the car to a transmission place they have said that my tailshaft is shot.
They have given me two options to fix the car.
Get a replacement tailshaft - He questions this as a 2nd hand one may well give similar probs. How much could I expect to pay for a 2nd hand tailshaft?
Take existing tailshaft out of the car and repair it - Apparently the CV joint in my existing tailshaft is shot and he can take that to an engineer and get the joint re- machined. This is expected to cost around $650.
What are your thoughts on both options? Is $650 an excessive amount to pay for this to be repaired?
Cheers,
Mitch.
Edited by sinstr
https://www.sau.com.au/forums/topic/251445-32-gtr-tailshaft-questions/
probably the cheapest way out is to get a 1 piece shaft made. the standard 2 piece shaft do tend to flog out the centre coupling/bearing. and it's prone to coping a whack every now and then too. UAS www.nismo.com.au sell 1 piece 32 GTR shafts.
Thanks alot for your quick reply guys.
That 1 piece tailshaft looks like a good option. If I were to get this would there be anything else needed to make it fit or its it a simple bolt in job in replacement of the 2 piece?
Also are there any advantages / dis advantages going the 1 piece over the 2 piece? And will it be as strong as a standard 2 piece. By the way my GTR is making around 270kws at the wheels so would this be suitable.
Also if anyone has one of the UAS 1 piece tailshafts please post up with your feedback :(
Cheers,
Mitch.
Edited by sinstr
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
