1990 R32 Gtr
110000 genuine kms
Meticulously maintained
Rare raven blue colour
700cc injectors
Bosch fuel pump
Adjustable fuel pressure reg
Apexi power fc
Hks turbos
s/s nizmo exhaust
Big aftermarket intercooler
Spitfire coils
Nolothane rear subframe bushes
2 way lsd (with orginal spare diff)
JVC dvd player
19" wheels
Gearbox recently rebuilt
Valve clearance recently done
Comes with Reg and RWC
Car is very quick: 275awkw, 300rwkw with dyno sheets to prove it. Car has run a 11.7 at calder with time sheets to prove it.
Price: $19,000 neg
Contact: Ralph on 0411512344
Car is in melbourne
https://www.sau.com.au/forums/topic/251578-1990-r32-gtr/
Bump price drop $16000, car needs to go this weekend!! The car now has 4 new tyres and just got the rwc done today, also re-tuned yesterday for better fuel economy but still made 274.4awkw. I need to pay for my wedding reception!!
https://www.sau.com.au/forums/topic/251578-1990-r32-gtr/#findComment-4412332
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
