will the 34 D-jetro work in a 33 Gtr?
And also the diff? are they interchange-able at all?
Sorry, wasn't watching the thread.
As Paul said re the D-Jetro. Diff I'm not sure on. I know the rear diff ratio is different in a 33 but really can't comment on the front one. I'll see what I can dig up.
Thanks guys,
does the D-Jetro come with nipples?
Item: Z-Tune copy side skirts and rear pods
Price and Payment Conditions: SOLD
Item Condition: Unfitted and unpainted
Reason for Selling: Can't be bothered getting it fitted and painted.
Item: Z-Tune copy front bar with lip
Price and Payment Conditions: $550 (pickup only)
Interested in R34 intercooler and HKS oil cooler.
What is the condition of HKS oil cooler?
Can you post pics?
Located in Sth Melb 3205. Please advise delivery costs for both items.
Cheers
Pete
Can you post pics?
Cheers
Pete
Pics attached. I'll organise a shipping quote and get back to you.
  • 3 weeks later...
Hi I will get the PFC if they include 2*map sensor and other things i need. and they will fit 34GTR? I also can pick up. please let me know as soon as you can. thank you
  • 3 months later...
Willo , what's the dimensions of the oil cooler ?
Brad
I'll pm you tonight. The core is 50mm thick with dash 10 fittings (1/2") from memory but the other dimensions I don't know off the top of my head.
Also up for sale:
Item: RB26 Tomei Type B Valve Springs
Price and Payment Conditions: $600
Item Condition: Less than 10,000kms old
Reason for Selling: Upgraded.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
