Hey guys i have a r34 25gt and about 1 week ago while driving my engine light came on, so i pulled over and turned off the engine and turned it back on again, it was gone for about 15mins and it came on again, i took the car to this crappy mechanic and they didn't have the computer to analyze the error code. But they told me to reset my computer by taking the battery and if the engine light dosnt come on again everything should be fine, so i did what he said and surely the engine didn't come back on.
But today while driving to work the engine light came back on, but after work i took it for a drive and it didn't come back one....anyone have any ideas what problem this could be?
I called my local nissan dealer and they said their computer is not compatible with imported skylines...is there any mechanic around Sydney that has a computer that can analyze the error codes?
also a quick question i have a semi auto r34 and theres a button with A/T SNOW what is that for?.
cheers
Edited by MaShi
https://www.sau.com.au/forums/topic/251878-engine-light-randomly-turning-on/
sorting this out is just so simple if you put a teenie bit of effort in - you absolutely don't need Nissan dealer or anyone
you can get the error code in about 2 mins all you need is a piece of wire - I am not going to explain everything as the topic has been covered many times on here (SAU) - what I will recommend is YOU download the R34 Engine Manual - FREE ON NUMEROUS WEBSITES - just google it - then spend all of about 5 mins reading it - it tells you everything you need to know and do
you will probably then work out you have a Code 21 and take all of our words for it that means new coils (Splitfires best) - we all have been thru what you are now experiencing - FIRST just the checklite restart and all appears OK but soon enough if you do nothing one day the car will begin very serious misfiring maybe even to point of not driveable - not good if you are 100s k s from home
believe me you don't need Nisssan dealer or mechanic to fix the problem - so save big money avoiding labour service charges and get to it
Cheers
i wen to get it tested today, came out with error code 21 : main ignition system (something like that), the mechanic reset the computer for me and said if it comes on again come check it again and if its the same error code then its your coilpacks, and on my way home the engine light came on again.
so how long do you guys think i have until it start to mis fire?
mine came on when i was driving home from work, it came up with the engine light, did an engine diagnostic cuz it sounded n drove like a rexi (no offence lol :D )...
replaced all coils with splitfires n been beaut eva since.. no point replacing the bad 1 cuz if 1ns screwing up its more than likely they will all start going...
strange it aint miss firing already tho :laugh:
<br />yeah the car is not shaking or miss firing.... its pretty weird<br />i wanna make sure before spending 700$ to change them <img src="http://www.skylinesaustralia.com/forums/style_emoticons/default/sad.gif" style="vertical-align:middle" emoid=":3some:" border="0" alt="sad.gif" /><br />
<br /><br /><br />
its a real nuisance about o.e.m R34 coils but there is no option except pull your coils out and find the duds - my experience was Code 21 randomly appearing first with absolutely no noticeable effect but within less than a 1000k big trouble - it was suddenly so bad it was virtually undriveable luckily I was only about 3 k from home so ran it back anyway on about 4 cylinders as it was early Sunday and no traffic about - not a nice experience - hardly made it back - put in new coils and instant new car feeling!
this is what you need to do.
Take the kick panel off, take the ecu out of the car (undo the 10mm bolt) unplug ecu from harness.
Then plug the ECU back in, when you put it in just tightening up the 10ml bolt is NOT good enough, give the bolt 2 turns then push the plug in on EACH side then repeat this untill the bolt is tight.
Make sure the ECU is pluged in ALL the way and there is no gap. I have seen this happen on countless nissans where people DON"T put the ecu back in properly and they get error codes and engine lights because a sensor does not have a good enough connection.
Try this and let me know how it goes before spending big $$$ on coil packs. Even if it looks like its connected properly, still take it out and put it back in the same i explained.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
