Pinging
I noticed my V35 pings quite a lot. I had it tuned by a very trustworthy guy who worked on my Zed and pinging in a turbo engine is a real worry but not so much in an NA. Anyway he said the computer on the V35 has everything tied up so he can't adjust it.
Has anyone else noticed excessive pinging?
cheers
Geoff
I was in a roundabout in Sunbury yesterday and I momentarily about to start but saw a car that suspectly going to turn my way so I brake, then saw the car wasn't, so I accelerate again quickly and had a tyre chirp than a rattling kind of noise ta ta ta ta, is that the one you're talking about? or is that my ESC turning on? it's happening too quick I didn't have chance to look down and see if my SLIP light was on as it's too dangerous to do that in the middle of a busy roundabout.
Did your mechanic check the timing Geoff? Is the timing adjustable by rotating the CAS like on the Zed or is that also controlled by the computer? Shouldn't be out of whack I know but it might have been fiddled with by the previous owner. And I assume you are running with 98 octane fuel.
Cliff
if anyone fiddled with mine it will most likely be Nissan dealer doing the 50000km service.
does anyone have info if the timing on V35's VQ35 is the same as local 350Z ? as I suspect nissan would have used 350Z's data to perform any engine related service.
hey mate that is just your traction control / VDC kicking in.
has happened to me a few times as well when my previous tyres were bald and in the wet
I seem to get pinging on mine a bit too... haven't quite figured out the cause. Seems to happen at low rpms when the car is coasting in gear then i get back on throttle...say under 2k rpms. It also occasionally happens during same coasting in gear to back on throttle but over 2k rpm so e.g. 2400 rpms. Anyone noticed these cars are really sensitive to heat ? Or is it just mine lol =/
I get exactly the same symptoms as Touge Kyousou above but in a VQ25DD engine...
in that case I have not experienced the pinging...
although it happened like a rattling engine sound 1-2 second after the car haven't been started for 2 days.
is that cos there's no oil in the valvetrain/head?
Correct - that is the lifters you can hear
 Share
    • I live in Thangool I cannot buy E85 fuel there or Biloela not many servo's sell it Rockhampton the  Ampol in Gracemere won't even sell 98 , it's hard to own a high performance car in CQ and NQ .
    • Sounds like a good excuse for a trip to Australia! But yeah, trying it out is probably the best way to go about it. Please report back what you find.
    • Well as I will have both S1 and S2 front parts i will see what works best out of the two. Im not fussed if i need to drill extra holes, and im a big fan of Nutserts/rivet nuts and a nice painted dome head bolt as a way to hold stuff in place where plastic clips have broken and are hard to source new ones
    • Yeah truthfully it seems like the headlight supports for the ALTIA and S2 should be the same, but they aren't. I can only guess that the grill area of the Altia bar is different to the grill area of the S2 bar. Either that or it's due to the S1 bar having an angle up to the center bar that the Altia doesn't, or something. That said, I recently bought an Altia bar myself, and I fit it over the S1 brackets and thought "Yes, this will all work fine" so even as I doubt my own words as I post, I also daresay you'll be okay.
    • Me too. Apparently the new version of Invision will allow some customisation so look forward to a 'Love' reaction and a new 'Like' icon.
