hey...i need to find a wreckers place and i looked in the wreckers thread in the sticky section and really i dont know any of those places as i live in bayside...so im trying to find either a wreckers near there or ill make the trip to oakleigh to Oakleigh mechanical repairs
has anyone used them for wreckers parts etc? are they recommended and good?
sorry if this is a re-post
https://www.sau.com.au/forums/topic/252103-wreckers/
theres a place on kangaroo road in murrumbeena near warrigal road. have been there a few times i find for what i needed his prices were reasonable.
the guy is great and very helpfull giving you advice on how to install and helpfull etc..
not sure on name but if u drive down kangaroo road there is nissan signs and shit everywhere
https://www.sau.com.au/forums/topic/252103-wreckers/#findComment-4361567
there is a place called "fujima"
i dont have the contact details, but if you head down cheltenham rd, then turn left onto the street that runs right next to eastlink, its half way down smile.gif
https://www.sau.com.au/forums/topic/252103-wreckers/#findComment-4362770
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
