Mattrix Posted September 19, 2003 Share Posted September 19, 2003 Hi guys, i'm going to be attempting in the near future a swap of my l28e in my 280zx to an rb20det and wanted to ask in here a few questions that i have. firstly, how difficult is the conversion? what sort of things will i need for the conversion? is there anything i need to take into account? secondly, i was thinking of selling the rb20 turbo and putting a bigger turbo in, such as an rb25 turbo. Is this possible? also, how much would i be able to a) sell my rb20 turbo for, and B) buy an rb25 turbo for (and where from)? lastly, does anyone know where i can sell my l28e once i've done the swap and approx how much i will get for it? thanks for you help guys Matt Link to comment https://www.sau.com.au/forums/topic/25250-280zx-l28e-to-rb20det-swap/ Share on other sites More sharing options...
dojobi Posted September 19, 2003 Share Posted September 19, 2003 I'm not too sure on the selling prices, but the RB25 turbo onto the RB20 engine is definitely a good idea. I also think the RB20 swap is a good idea too - although I don't know how hard it is. People have done it before, so someone should be able to help you. You'll get much better economy and the benefit of a tweakable engine with a huge aftermarket parts catalogue. The RB20DET also has more power than the old L28E. The RB20DET has 158kw/265Nm and the L28E has roughly 100kw and 200Nm from memory. Finally when you're done, you must take me for a spin in it. Link to comment https://www.sau.com.au/forums/topic/25250-280zx-l28e-to-rb20det-swap/#findComment-537011 Share on other sites More sharing options...
dojobi Posted September 19, 2003 Share Posted September 19, 2003 One other thing. The L28E may have a better torque down low. I'm sure an R32 owner in here will be able to help you out as there are some R32s going around that aren't too laggy. Link to comment https://www.sau.com.au/forums/topic/25250-280zx-l28e-to-rb20det-swap/#findComment-537015 Share on other sites More sharing options...
RPMZ Posted September 22, 2003 Share Posted September 22, 2003 It’s a fairly expensive exercise to put an RB motor into a Zed, therefore you should be putting RB25DET or even RB30t, as those extra cubes will make the car much better to drive. To put an rb26dett into a Zed costs around 10k (excluding motor). Do it once … do it right. Talk to SPEED TECHNOLOGY as they have done RB conversions into Zeds. 03 9873 5400 Link to comment https://www.sau.com.au/forums/topic/25250-280zx-l28e-to-rb20det-swap/#findComment-538735 Share on other sites More sharing options...
Mattrix Posted September 22, 2003 Author Share Posted September 22, 2003 Thanks for the replies guys I didn't think it was going to be that complicated, rb25 is out of my budget so if i was going to do anything it'd have to be something a bit cheaper. I'd like to do it the best way that i can first time around but a lot of money just isn't available right now and i'd still like to do something. From what i can gather the performance is up'd by about 150% when going from l28 to rb20, and i heard that the rb20 isn't too hard to fit in... (?) Anyone else able to offer some advice? thanks Matt Link to comment https://www.sau.com.au/forums/topic/25250-280zx-l28e-to-rb20det-swap/#findComment-539453 Share on other sites More sharing options...
RPMZ Posted September 22, 2003 Share Posted September 22, 2003 The motor won’t be much compare to the rest of the project: - New exhaust - New plumbing for the cooler - New engine mounts/ or modified engine mounts - New clutch - New G/box - Will need new G/box cross member as L series motors lean to one side, yet RB motors to the other - Brakes upgrade for engineers report - Wiring - Intercooler - New ECU (stock ecu may do to start with) - New fuel pump, fuel reg. - Sump might need mods to clear cross member - Labor ( unless you plan to do most of it your self ) - Engineers report etc. etc. I think you’ll end up spending at least 10k on the conversion,…… and for that money you might as well sell your car and buy a R32 GTS, which would be a better car to play with. These are just the most obvious things that will be required. I know a bit about it as I am also putting an RB motor into my Zed next year. Also a friend has fitted an RB26 into his Zed. Link to comment https://www.sau.com.au/forums/topic/25250-280zx-l28e-to-rb20det-swap/#findComment-539519 Share on other sites More sharing options...
rsx84 Posted September 22, 2003 Share Posted September 22, 2003 i did the conversion into my r30, now the r30 had the l20et so if your car has the l28e then by all rights the engine bay and sterring arrangment shoud be much the same. Link to comment https://www.sau.com.au/forums/topic/25250-280zx-l28e-to-rb20det-swap/#findComment-539554 Share on other sites More sharing options...
rsx84 Posted September 22, 2003 Share Posted September 22, 2003 P.S. mind cost about 9000 ( thats, new king springs, konis adj front and rear, new slotted brake disks, racing pads from bendix, r32 half cut, hybrid intercooler kit) oh yeah and the price of the car as well. Link to comment https://www.sau.com.au/forums/topic/25250-280zx-l28e-to-rb20det-swap/#findComment-539567 Share on other sites More sharing options...
Mattrix Posted September 25, 2003 Author Share Posted September 25, 2003 Hey guys As for the new bits i'll need, i've taken a few of those things into account already, i've got a 2 1/2 " exhaust all the way through, i've priced an engine ($900 with electricals) and g/box ($350), not sure what those other parts will cost. How hard is it to modify the engine mounts? gearbox mounts easy to find and put in? as for getting a skyline, well, a) no cash, B) my car is my child that no skyline could replace (you should know, you're a fellow z driver) Mattrix Link to comment https://www.sau.com.au/forums/topic/25250-280zx-l28e-to-rb20det-swap/#findComment-544930 Share on other sites More sharing options...
dojobi Posted September 25, 2003 Share Posted September 25, 2003 Matt, you know you want a Skyline. Sell the Z and step up to a real sports car Those prices look good btw. It does look like it'll be a very expensive excersize if you take the prices of the parts mentioned above into account, though. BTW RPMZ, that is a sweet Z you've got there and a nicely done site (although I can only get it to work in IE). How do you find the 7.3:1 compression ratio? Is your car a lag machine? Link to comment https://www.sau.com.au/forums/topic/25250-280zx-l28e-to-rb20det-swap/#findComment-545098 Share on other sites More sharing options...
RPMZ Posted September 25, 2003 Share Posted September 25, 2003 hehe .......... yes Zeds are addictive......... but the project will end up costing a lot more than what you think....... so you should be aware of that. If you don't have much cash I would start the conversion as these thing always end much much more than anticipated, and I'm sure you don't want your car off the road for months. P.S...... I still think 2L isn't much for a bigger 280zx..... Link to comment https://www.sau.com.au/forums/topic/25250-280zx-l28e-to-rb20det-swap/#findComment-545103 Share on other sites More sharing options...
nemz Posted September 25, 2003 Share Posted September 25, 2003 thats one kick ass site man p.s matrix the r32 gts-t will be cheaper all up i reckon man, plus nicer all round car Link to comment https://www.sau.com.au/forums/topic/25250-280zx-l28e-to-rb20det-swap/#findComment-545115 Share on other sites More sharing options...
RPMZ Posted September 25, 2003 Share Posted September 25, 2003 MIC33R .......... lag ............... since I've put the GT30 I forgot what lag is (awesome turbo) boost from 2500 rpm 7.3:1 comp ratio is a bit too low, however with a 1100 kg car is not much of an issue and the car is good off boost as well, and at 4000rpm the car already makes 200rwkw (racepace dyno) 12.2 @ 117mph 12.1@116mph P.S. I have to agree with nemz last post ... Link to comment https://www.sau.com.au/forums/topic/25250-280zx-l28e-to-rb20det-swap/#findComment-545118 Share on other sites More sharing options...
dojobi Posted September 25, 2003 Share Posted September 25, 2003 Well I won't argue with those times It sounds like your car is an absolute beast (the vids were nice). Let us all know how the RB transplant goes. BTW which RB is going in?). Mattrix, maybe you could look into the L28ET idea if you don't sell it and buy a Skyline From the looks of RPMZ car, they're certainly no slouch. Can you can just swap the heads and pistons to upgrade the L28E? Link to comment https://www.sau.com.au/forums/topic/25250-280zx-l28e-to-rb20det-swap/#findComment-545129 Share on other sites More sharing options...
RPMZ Posted September 25, 2003 Share Posted September 25, 2003 ......... well .......... once I crack 11s ........... (hopefully soon) the motor will be for sale next year with the cooler, Autronic and lots of other goodies as I got an RB26 that is waiting for a rebuild which will be replacing the L28 next year ......... :) Link to comment https://www.sau.com.au/forums/topic/25250-280zx-l28e-to-rb20det-swap/#findComment-545143 Share on other sites More sharing options...
nemz Posted September 25, 2003 Share Posted September 25, 2003 if you have the money to do up a zed, and the passion and the time, then go for it, you will have a nice car, but if not ure just gonna end up with something that isnt what u want, gonna have probs gonna be off the road, better to just keep what u have for a while and save for an r32 p.s will the rb26 add much weight"? if it dont meh thats gonna be one hella fast car Link to comment https://www.sau.com.au/forums/topic/25250-280zx-l28e-to-rb20det-swap/#findComment-545153 Share on other sites More sharing options...
Mattrix Posted September 27, 2003 Author Share Posted September 27, 2003 yeah, l28et would slot in nicely but i'm not sure what my chances are of finding one, and even then i dunno if i'd get it for a decent price. Or alternatively, how would i go sticking a turbo on the l28e? difficult? expensive? the engine only has 169,000km on it, so it's probably got plenty more years left on it (i hope) and guys, please, i'm not buying a skyline i love my zed, there's not many on the road and i like it that way. Link to comment https://www.sau.com.au/forums/topic/25250-280zx-l28e-to-rb20det-swap/#findComment-546547 Share on other sites More sharing options...
floody Posted September 27, 2003 Share Posted September 27, 2003 I just thought I'd add that if you can source a sump from a Z31 200ZR (like a 300zx, but with an rb20det from the factory), that should make the conversion a little less painful. I'd like to pull the RB30E and five speed from my R31 and stick it in a 240z, don't think that will happen though... cheers, floody Link to comment https://www.sau.com.au/forums/topic/25250-280zx-l28e-to-rb20det-swap/#findComment-546717 Share on other sites More sharing options...
Mattrix Posted October 6, 2003 Author Share Posted October 6, 2003 Ok, latest update for those that are interested. Found out that a guy at my church knows how to drop an rb20det into my car and do all the necessary work involved. Says that it'll be about $4000 all up but he's still looking around to see if we can do it for cheaper. It's looking as though i will get the r31 rb20det and put an rb25 turbo onto it, get a skyline radiator, new gearbox and all electricals, new fuel pump, new engine mounts and gearbox mounts, and not sure what else my mate has in mind, but it sure is looking exciting. will have to keep everyone updated as it happens, and take photos as well. Matt Link to comment https://www.sau.com.au/forums/topic/25250-280zx-l28e-to-rb20det-swap/#findComment-557433 Share on other sites More sharing options...
RPMZ Posted October 6, 2003 Share Posted October 6, 2003 $4000 .......... that is cheap as chips ............... let us know how you go, as I'd love see how it goes and how much it ends up costing. Link to comment https://www.sau.com.au/forums/topic/25250-280zx-l28e-to-rb20det-swap/#findComment-557446 Share on other sites More sharing options...
