R33 Gtr Parts, Tomei Cams, Cam Gears, Sard 660cc Injectors With Std Rail,
Looks like you were right on the T pattern! I did that and it's finally fixed! Thanks a bunch.
Replacing the entire system with a Bosch Motorsports ABS system fixes the issue @PranKhas Probably not the cheapest nor cost effective way to fix his ABS problem 😂 -
