so i did a search and found that alot of ppls where missfiring at 4-5 k
well mine pretty much dies in the ass at 6-7k?? also sort of miss's a little through out the whole rev range whether its under power of not (most noticeable at 3k)
but it only started to do the 6-7k thing after i changed the plugs
plugs are gapped to 0.8
mods are
turbo back
boost controller (between 10-15psi)
fmic
and pods
any ideas?
https://www.sau.com.au/forums/topic/253118-gtr-miss-firing/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
