Custom Coilpack Covers - Gb#5 - Rb20, Rb25, Sr20, Ca18
  • Replies 45
Posted Images
hey guys sorry for such a delay
Hello, do you have any more pics available of any other Nismo designs besides the ones already in the links in this thread? Im interested in a Nismo design just not 100% sure of what I want yet.
have a squizz through the previous group buy's mate, im sure youll find a few variations, or if you cant find anything you like just tell me what you want and ill get it drawn up :ermm:
can u make one with this design
cheers
julz
sending it away now to be drawn up :banana:
Yeah think i'm in for this one too,
still uncertain about the coils and water thing :(
let me know if you want to place an order mate :)
as for the water getting to the coils, its unlikely that a huge/damaging amount of water will ever get in there - even with no coilpack cover. but even so it just drains out the rear of the coilpack valley :) - happy to be corrected if im wrong! but there has been no complaints/feedback on this issue :banana:
Edited by Brycey
hey guys, sorry for the brief quiet period, there was some big contact delays between myself and AM performance due to the stinking great big heat wave down south, everything is back on track now and the GB will be extended from monday the 9th to monday the 16th, to make up for any lost time!
also now would be a good time to get in with your orders so there is no mad rush/delays at the rear end of the GB :P
:domokun:
Bryce did you receive the email I sent you with the design??? Might have something to do with the reason above but just let me know if you got it or not :geek:
sure did mate and has been replied to, sorry once again for that delay, i have been playing a bit of catch up this weekend! everything in Adelaide looks to be getting better so the group buy is back on track, but i hope everyone in Melbourne is fending ok!
:geek:
ending this coming monday (the 16th)!!
currently waiting on AM Performance to send me a few drawings for Cruzin33, Shenq, R33whitejeffo and Gunmetalgtr32
sorting an order out with ossie 21
reiterated interest from muz and drpheel
have received payments from bainator, stargate and rolex
also if you are still interested in placing an order then there is still plenty of time between now and monday (obviously) to get in, but please try and get all orders/payments in sooner rather than later so there isnt the typical week overhang of confirmations and waiting for payments to clear :D
if your name isnt in this post, then please pm me and chase me up! apologies in advance if i have missed anyone :(
have a good night! :P
Taso84 - just sent you a PM mate :(
group buy closes tomorrow night! still time to get in!
pretty sure everything is up to date, but once again chase me up if you have any questions!
:D
group buy closed!
still a bit of confirming and order collecting to do yet, but i will keep this topic updated for the buyers :):P
just a quick update, everything is well and truly under way, there was some overlap for delayed payments etc but everything is on track :D any worries then pm me or post up!
:P
hey guys sorry for not keeping this up to date, things have been a little frantic :P the covers are nearing completion but as usual the powder coated covers will take a couple of days longer. will write up when i find out more info :down:
last i heard mate production was finalizing, so i was under the impression that the packages would have been sent late last week, can only assume that this would be the week. ill try and get in contact and find out some specifics
all packages are typically sent registered, so once they are sent i will be able to get the codes for all you guys
:D
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
