Hello all,
After a crap 2007/8 recovering from a car crash I decide to go back to uni in 2009 and do another degree. My 3rd preference was a Bachelor of Exercise & Sport Science at Charles Darwin Uni and I was offered this course. The only people I know in Darwin are my aunt & uncle who would probably let me stay with them short term but ultimately I'd need my own place. I have until Friday 23rd January to respond to the offer. If I accept then I have <6 weeks to pack up, find a tenant and move!
My questions are:
Is Charles Darwin uni any good?
Has anyone on SAU done or currently doing this specific degree?
Is it easy to find accommodation near CDU?
Is there a decent import scene in Darwin?
Is it easy to get a heavy modified GTR serviced and tuned (PFC) in Darwin?
What are the police like in treating import drivers?
Are there many decent single chicks in Darwin aged 24-34?
I'd appreciate any answers to the above questions as it is a pretty big decision to make in not much time.
Thanks
https://www.sau.com.au/forums/topic/253172-should-i-move-to-darwin-to-study/
Hello all,
My questions are:
Thanks
youve probably already made your decision by now.
the uni is alright. not the best, though.
youd probably have to look in the paper for shared accomodation. me and my missus are looking for a house mate. if you moved in with us you have to let me take your car for a spin of course :D
hmmmm, havent brought my car into any workshops in darwin but id trust dave cheetham.
police arent as strict as down south. just dont drive around with bald tires and overly dark tint.
single chicks and single mums haha. darwin girls tend to be a little stuck up i reckon.
youd probably have to look in the paper for shared accomodation. me and my missus are looking for a house mate. if you moved in with us you have to let me take your car for a spin of course :P
Thanks for your response - I was beginning to think no-one from SAU lived in Darwin.
I deferred for a year and asked to still be considered for my higher preferences. It will take me a year to get my house in a state to be able to rent it out (which I'd need to cover the mortgage).
Good to get a name for someone who can work on GTRs in Darwin though - cheers.
I'm sure we could swap cars (my 32 for your 34) at some stage although I wouldn't need to move in to do so.
Stuck up women eh... I could probably cope with that...
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
