Hi mate..still have the TE37??? Im interested..Is it ok if i come have a look on the 26th..sorry man,thats my only day off for next week...let me know. Thanks
C'mon guys .. no more price drops .. these are dirt cheap now!
Im not going any lower just incase there are people watching this thread expecting another price drop..
Guys look around do your research, and these are nothing compared to what you would usually pay!
Interstate buyers, PM me if you have any concerns over the transaction or feel insecure with the shipping.
MRXTCZ
Like i said, i gotta' get rid of them..
Taking offers over 1900 for Works and TE37's ..
Organise own Courier..
And Volk F-Zero's are open to offers over 900 now.. Info needed i know .. got no time .. im reply right now on my phone .
MRXTCZ
hey vikz, hows it going?
are the TE37s still for sale?
what size tyres are on them & how much tread - what car did it come off, any pics fitted to the car to see how fitment is :(
these will go nicely on my 34 i rekon :P
cheerz
F-Zero pic..
Here is some pics of these wheels fitted to my white R33, except the ones I have are 17" x 8" +32 and 17" x 9" +40
I bought mine for well over $1000, $900 is a pretty good price people :P
Hi XTC, are the Volk TE37s still for sale?
can you pm me your #, i wanna come check the rims out tomorrow if possible.
is there much gutter rash on them?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
