Respray
  • Replies 65
i work at a crash repairer and i can tell you it is not cheap. would be cheaper staying the same colour than changing the colour. doing the engine bay will add alot more money to the job too.
so how many slabs of beer will it take to have you respray the nose of my car, just touch up stuff and a ding , I dont have the gear here to do a proper job or the clean area to do it.lol
you should never mention skills, maybe would could trade skills if you need anything done..?
https://www.sau.com.au/forums/topic/253273-respray/page/2/#findComment-4387598
Car Cosmetics at Lonsdale they are awsome and very well priced ...
Im going to say it and i dont care if it gets taken down or what ever.
That dude is shit, plain and simple. He done my GTR, had some rust where the rear right mudflap screws to the body. I told him i wanted it cut out and sprayed as i will keep the car for a while, and i had to go through regency (for an unrelated defect but i dont want dodgy shit) I got it back and was just full of fiber fill, topped off with bog and painted. I confronted him about it and he didnt want to have a bar of it and said i told him to fiber fill it, haha ok what ever.
I ended up going to extensive restorations at lonsdale, they cut the inner and outer skin out and made new ones and welded it in, much better. Cost the same amount as bringing to BOGmetics too.
If you want someone skilled in the art of bog sculpting go to car cosmetics, i think its all he knows.
Edited by GTR1993
https://www.sau.com.au/forums/topic/253273-respray/page/2/#findComment-4390091
To save making another thread.....anyone got a rough idea on how much it will cost to get the holes in the front guards for the side indicators covered (Preferably metal as they are standard guards)?
Best to just take them to a local welding shop and ask them if they will do a cashy. it shouldn't take them long to do, should only cost an hour or two of labour. Then just give them to paint shop and they will be able to bog them up and smooth them out.
https://www.sau.com.au/forums/topic/253273-respray/page/2/#findComment-4391671
Performance Spray Painting & Crash on stanbel rd, salisbury plains.
They just did my HR31, new roof skin, closed doors respray but colour change, some old front damage fixed, welded up holes in boot and where antenna was, rust cut out behind tail light = $5200 (including remove + replace all windows and seals)
I used to work there and only ever saw top quality work in that place. The owner, George is a gun spray painter with some of the best blending/colour matching skills ive ever seen. And doesnt charge through the asshole.
Has sprayed plenty of old classics and show cars too
https://www.sau.com.au/forums/topic/253273-respray/page/2/#findComment-4391726
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
