Hi Krzysiu,
thanks for researching, but the deliema is that i get phone allowance up to $100.00 so i have to get it on a plan. Other option is to get a NOKIA N96 with a plan than sell the phone, than buy the 8600. Hmmm...... what to do???
https://www.sau.com.au/forums/topic/253341-mobile-phone/#findComment-4380730
I'm in Hong Kong ATM coming back on the 1st it's a bit hard to help cause you wud have to trust me by sending me the money to get it for you, did you want me to get a price check anyways?
mate please do, i have found a shop that sells it. but the price they want is extremely high, lets say i can buy a N96 and a quater. greatly appreciated.
And make sure it's made in Germany/Quad Band and only has 128mb of mem.
https://www.sau.com.au/forums/topic/253341-mobile-phone/#findComment-4382958
N96: over rated and over priced (about $1300 RRP)
Luna: 2g phone with steel casing, 2mp camera, and radio. I would not pay over $300 fr this as it's old tech.
E66: better option than the luna. 3g, aluminium casing slider with push email, RRP is about $650 unlocked or free on plans about $60 and above. It's a keypad version of the E71 really, with the screen flipped 90 degrees.
N85: a slimmer, newer version of the N96 with less memory (but expandable to 16gb) no dvb-h (not supported in Au anyway) but does include an FM transmitter (liten to music or take calls through car stereo via FM) Still has GPS, Bluetooth and push email, but in a much less chunky package
plus the screen is an organic LED, and much better to view than the N96.
Plus it's only about $1k RRP, and available on plans unlocked.
I work for a phone company, so if you want more info, feel free to message me.
for all the stats, check out gsmarena.com though don't pay attention to the battery life figures, they're full of crap.
Luck
https://www.sau.com.au/forums/topic/253341-mobile-phone/#findComment-4383209
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
