Hey all.
Just got my V35, and so im on a cleaning bender.
The black and chrome wheels are clean, but i want to clean them right.
Whats the best thing to use?
I have some AutoSol lying around, i know thats a great chrome cleaner, will it be ok for black wheels?
If not, whats best? The wheels are mainly black, with chrome dishes.
Thanks all.
https://www.sau.com.au/forums/topic/253558-cleaning-black-and-chrome-wheels/
i just use normal soap and water.
you can use a rim cleaner just make sure its not too strong or can strip the paint / finish of the rims
i finish of with some autoglym alloy wheel seal, so it stays cleaner for that little bit longer
post a pic of what wheels u have. You need to be able to differentiate between chrome, anodised or polished lip. There are different types of cleaners depending on what u have. Eg: you don't want to use an abrasive cleaner that may strip clear coats off chrome or anodised lips. Generally car shampoo and water works best. Plenty of wheel cleaners out there, jst make sure they are clear coat safe. If it is a polished dish, then autosol should be fine.
Edited by n15m0
yeh i went to a car wash once and i had my old anodised rims VOLK GTC and the chemical they used to clean the rims actually stripped the anodise off the rim! and it stained the rim! i had to get the whole damn thing taken apart (all 4 rims) and repolished
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
