well at the moment all the good gear is off my stagea due to being defected.
i have for definate sale my G-MAX rims. they are 18x8.5 front and 18x9.5 rear. not sure of offset but the fronts sat really nice under the guards but the rears protruded about 5mm. There is a bit of gutter rash on the two back rims as it just took me and the missus ages to get used to parking a bigger car with wheels that stuck out also. $1200
i currently have my highflowed GT3071 sitting in the shed, it will be going back on in a couple of weeks unless it goes to another home. it was built by Bill here in adelaide at ATS and is 6 months old and has done about 4000km running 12psi. it will come with all the lines necessary but all i will ask in return is a standard wastegate actuator as mine is modified to suit the new turbo. it has a nissan comp cover on it to help fool the police if they have a look but regency still found it. $2000
also off my car at the moment are my beloved kei office coil overs. these are to SUIT A RWD STAGEA ONLY. i got these over from japan 2nd hand myself and had the rear shocks rebuilt by TSR over in Quensland. the fronts are 6.5kg and the backs are 5.4kg. these are height and spring rate adjustable and the fronts have camber tops. the shocks are not damper adjustable but i didn't get any bounce or saggy feeling when i had the springs set on soft or hard. $1500
please feel free to ask any questions
post-44842-1232534578_thumb.jpgpost-44842-1232534623_thumb.jpgpost-44842-1232534739_thumb.jpgpost-44842-1232536940_thumb.jpg
https://www.sau.com.au/forums/topic/253591-some-stuff-for-sale/
took the stag for a bit of a drive today. im petty happy with it back in its near stock form. these items will be for sale indefinatly now. im going to drop the turbo down to $1800 and am willing to swap the coilovers for a set of lowered springs plus cash my way. my time is worth to much for me to bothered swaping and changing stuff if the cops are just out to get us import guys.
rims are gone for now as a mate is picking them up to try on his BA XR6
That was the same feeling of my 33 after regency, gonna leave it stock.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
