1993 Nissan Silvia 2.0L Turbo - Great condition 109,500 KM's Automatic transmision. Clean interior, very responsive engine - very stock car.
- Great daily driver avg 450-500km's per tank of petrol combined fwy / city driving.
- Serviced Early Jan 2009. RWC provided with sale.
- Club K's S13 Silvia with HICAS and the usual options e.g. climate control, electric windows and electric fold in mirrors.
- Sony MP3 CD player, alarm, brand new rear tyres.
Overall in pretty good condition, the only real problem is clear coat fade on the right front fender (see pic) and air con recently stopped being cold which might just be a fuse as it went from really cold to nothing in a day.
Located in Avondale Heights 3034 but I drive to the cbd for work sometimes, can arrange for it to be looked at there.
Asking for $6,800 but feel free to make an offer.
0421973613 - Michael.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
