Took The GTR to into a tuner... drove it up, he said turn it off.....
Its a big end bearing...
Apparently the engine needs a full rebuild...
and have a quote in my hand for $10,000.
Is that about right for a engine rebuild?
i can put the engine componants up if you need.... :S
https://www.sau.com.au/forums/topic/253659-weird-noise-found-engine-fked/
  • Replies 89
ouch... I know that sound all too well;)
many things can kill the big ends, from contaminated oil to detonation to oil starvation... make sure your builder finds out the cause before he puts it all back together otherwise you could have the same problem again
price all depends on what's going in and how much work is being done... could be a terrible quote or a great one
good luck
dood that sucks you only just bought that car didnt you???
Speak with Dirt Garage, he was quoting $7k odd from memory for a rebuild, although on top of that would be R&R and freight. Just check the parts your tuner/quote includes verses the quality of what Paul was offering, but over here $10k would be well cheap for parts and labour on a full rebuild.
Cheers Guys ill update with a full list of parts they will use etc soon, he is emailing me the quote.
And yer had it around 9 months now! lol oh well hey.
While im doing it i might as well put new turbos on to.. The tuner said the set up he quoted for will be good for 400 to 450kws so might get a bit bigger turbos then i was first thinking
10k sounds a lot for a bottom end rebuild (inc forged rods / pistons, unless they are tomei/ HKS etc) as eagles can be found for $750 and CP's for <$1000 now. that is what a lot of builders are using I see around here.
perhaps he is thinking an HKS step 3 kit :) really need to see what the quote is.
Post up the quote please.
A lot of people will say $10,000 is a lot (and may well be a lot without seeing what he's included) but few people know the real costs involved with an RB26 rebuild to safely handle upwards of 400kw atw
Advice? Speak to the people that have done it a couple of times and do not, do not take shortcuts
go back to the tuner, blame him for the bearing problem. Besides he should have told you to turn it off quicker and it could have been avoided and its his fault. Make him pay for your new engine and re-tune your new engine too! even though he was at fault for breaking your car.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
