  • Replies 89
-7s/-9s are 330rwkw or so.
-5's are 380rwkw or so...
You need to decide on that, and dont get HKS, they are not worth the price these days now exhange rates are up the creek, go with garrett
7k for the motot build & in/out limits you but then some of the parts aren't bad by any means.
Going off your original as per here:
Ok heres the parts list
-New Crank
-CP forged pistons
-Eagle Conrods
-Gates racing timing belt
-Tomei sump baffle kit
-Mines rocker cover baffle set
-Genuine Gasket set
-Tomei metal gasket set
- ACL Race Bearings to mains and Rods
You can cut out the sump/rocker baffles and the rods (stock is more than fine) if you need to save pennies as i think you wont get all of them in a 7k in/out budget.
You do need however, good ARP rod bolts, they are a key to the build.
Other than that the above will fit, and then 2.5k for the -7s/-9s/-5s and you'll probably end up around 11k-12k fitted and then probably tuning costs on top.
So a bit over the 10k but at least its a decent well equipped setup. Its pretty similar to mine actually except i have GT-SS (got them when the exhange rate was good etc).
u dont need the cam cover baffles, the std ones work fine. Just pull them out and clean out the gausing
the tomei sump baffle looks like this:
which is better than nothing, however its better to get extra capacity aswell as better baffling like this: (this one is setup for an external pickup)
Are you going to be doing lots of track work?
If not, with the right oil mods to the head/block as part of the initial build etc will easily suffice for a street car that might do 1-2 track days/year.
Baffles are not a requirement. Nice to have, yes. But not a neccesity if budget comes into the equation and the second thing to chop out...
with rods being the first place you can save cash if you need.
To give you an idea of the extra prices of my R32 GTR engine rebuild that was finished early 2008 not included in the list of major parts:
Engine balancing & machining - $1250
Head reconditioning - $700
Crank pulley bolt & washer - $20
Crankshaft bush - $18
Key x2 - $5
Oil filter - $15
Idler pulley - $286
Spark plugs x6 (platinum tipped) - $160
Front diff side seal - $15
Engine mount x2 - $170
Shim machining - $10
Rubber plugs x2 - $15
Washers x20 - $50
Gearbox crossmember bushes - $40
Silicon hose - $5
Clamps x4 - $10
Gear lever boot - $18
Coolant x3 - $35
Front diff oil - $30
Power steering oil - $18
Hicas oil - $9
Injector seals & O rings - $40
Motul oil 300V - $118
Motul oil 4100 - $60
New battery - $95
Total: $3192
My total labour bill was over $6000 but I had a lot of new stuff fitted.
Edited by writeoff
Its not cheap to do, you'll find that trying to cut corners will always bite you in the ass.
Doesnt matter how "great/cheap" an option is, there's a reason people dont do it - keep that in mind :P
Lewis Engines any one used them???
They any good??
There in Adelaide and have quoted me for the whole thing and tuning and they are pretty good!
But do they do good work??
by all accounts they stand by the workmanship. isn't there a few drifters using their engines?
have ot say, they look pretty well setup. I don't think you need a mega dollar build for your goals, just go the 6.5k rebuild, garrett turbos and away you go.
there ar a lot of stock engines making over 300rwkw, so the lewis engine will be good for your goal :P
save yourself some money (you don't need a lot of stuff that has been listed + you ahve a lot of good gear already).
How does this set up sound...? Its slightly cheaper
Deck square to tunnels
Bore and hone
Balance
Acid bath block
Reco head ,complete
Assemble engine from sump to covers
Water pump
Oil restrictor
N1 pump as per customer decision
R33 crank
Forged pistons and rings
H beam rods
Gates belt
Nissan gasket set
Mlsr steel head gasket
Acl race bearings
Remove engine , remove accessories refit engine and fit accessories run in and tune
combine that with a set of Garrett -9s?
ive used lewis quite a few times in the past getting speedway engine's machined up have never had a problem with them with any of the work they have done for me in the past
cheers dean
^ pretty good build above.
However if your just using -9's the added expense of rods really is hard to justify in my book, they will do over 400rwkw as proven many a time over (with good rod bolts etc)
For sure stick N1 oil/water pumps on there
Still no mention of decent rod bolts, only thing you'd make sure of really
yep...the list above is good but forget the rods...totally agree with Ash.
When will people finally get through their heads the stock GTR rods are bloody tough and only in the most extreme engines need to be upgraded (and by upgraded i dont mean to cheap chinese sh1t thats probably on par if not worse than re-sized stockers with a bolt upgrade anyway)
I didn't list them (as I count them as an essential part and was just listing extras) but I used Tomei conrod bolts - $205
Also remember that you will need a dyno tune after so remember to include that in your total cost estimate.
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity.
    • 100% the factory sender is tapered, that is how it seals (well, that and teflon paste or tape)
    • Thanks folks - I've saved a few links and I'll have to think of potential cable/adapters/buying fittings. First step will be seeing if I can turn the curren abortion of a port into something usable, then get all BSPT'y on it. I did attempt to look at the OEM sender male end to see if it IS tapered because as mentioned you should be able to tell by looking at it... well, I don't know if I can. If I had to guess it looks like *maybe* 0.25 of a mm skinnier at the bottom of the thread compared to where the thread starts. So if it is tapered it's pretty slight - Or all the examples of BSPT vs BSPP are exaggerated for effect in their taper size.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
