This is what you need to do.
Sell the power fc and buy a Vi-pec. Problem solved. Even with jetro your still limited. Vi-pec is your best plug in option.
Don't know about the Vipec?
This ecu is fast becoming the best plug in option for Skylines and other imports
I not even going to bother reading this thread, as Ash has the most posts in here and he is always right.
And my question doesn’t warrant a new thread, however, these ECU’s. Is anyone quickly becoming the “go to” person to have these tuned in Queensland?
  • Replies 48
And my question doesn't warrant a new thread, however, these ECU's. Is anyone quickly becoming the "go to" person to have these tuned in Queensland?
Mark Jacobsen at Godzilla Motorsport in QLD is a Vi-PEC dealer and also tunes Power FC.
He actually said to me when the Vi-PEC was released he doubted the Vi-PEC would be able to run the engine better than the power fc. He now acknowledges that the vi-pec is a better product.
So his drag car runs this ECU?
Mark/Anyone dabbled with these in Evo’s yet?
Mark/Anyone dabbled with these in Evo's yet?
No he still runs a MoTeC M800...i was too going this way too on my drag car but Mark suggested we wait and see if the Vi-PEC was up to all it was touted to be. After doing a few Mark phoned me and said the Vi-PEC is an amazing unit and just as good in my car as what the mega dollar MoTeC would be. He is far more experienced than all of all of on here put together and anyone that has met him or had any dealings with him knows he's a no bullsh1t straight shooter who calls it like it is.
Yes Mark has done a few EVO's as well.
Overboost cut is another nice feature of the Vi-PEC...whats stoping the Power FC in the unfortunate event of a wastegate hose melting on the manifold, a leak, a split hose or one popping off.
Temperatue controlled mapping...only allowing the engine to access parts of the map on start-up to prevent engine wear or shutting parts of the map down due to over-temp conditions.
The Power FC is starting to look like a glorified Nistune now isnt it.
Edited by DiRTgarage
Interesting argument in here....
Here's my 2c because ,well... it's a forum :)
I think everyone agree's that the powerFC is a top little ecu. It might also be argued that it's cheaper than the Vipec thing to buy and do the initial tune on if you don't need more AFM flow.
I've had a few of the PowerFc's and I think they are ok.
However.
I'm not a fan of the tuning clunk of the power FC. I had a stinger EMS (nothing special) inbetween drinks so to speak with skyline and powerFC ownership and from a tune point of view it's faster and therefore less costly (if you don't do it yourself). The datalogit looks like it came from a foriegn language. You can do anything you like but, really slowly.
My idea of an ecu tune is something that addresses the whole shooting match in the same way as the factory tune does. The powerFC now falls behind on road tune abillity too. Road tunes are important for accurate load adjustments. Newer ecu's that have wideband plugins offer a very welcome functionality.
Having been in a number of PowerFC equiped GTR's I can certainly tell when they have had the 2hr special 'power tune', they are dull compared to the tunes I put in mine purely because I have more hours spent on them.
Looking at the prices the Vipec is good value.
Selling the power FC = $1200 plus saving $600 for AFM's
Thats $1800 to play with.
Provided you had a tuner who knows the ecu. The Vipec is going to be giving you a sharp responsive car for less tune time and less money. Not to mention the other features you can play with when you are bored.
The interface is also something that lets you begin to understand what the tune is and offers you a starting point to get into self tuning the powerFC doesn't make easy.
  • 4 months later...
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
