look to see if there is a fuse for it, otherwise a diode or two will keep the factory alarm from seeing the door pins and ignition switch feed , stops the doors locking.
there might be a door lock relay under the dash, on the drivers side kick panel area, get down on your knees and look under the dash while holding the pin switch closed on the drivers door, turn the key to the on position. listen close do you hear the relay click? you might be able to unplug it ?
Edited by sapphiregraphics
https://www.sau.com.au/forums/topic/253983-r33-help/#findComment-4387999
every one could be correct here lol.the question is tho.are the doors locking as soon as you start the car or only until you go over about 25 kmh? if its locking as soon as you start the car then its the alarm,if its locking when you go over about 25kmh then its the factory option locking and there is no way around that unless you feel like disabling your rear window demister in the process as they are tied in together.
Jack
https://www.sau.com.au/forums/topic/253983-r33-help/#findComment-4388013
Jack
good call jack forgot about that one,,in which case, find the Vehicle Speed Sensor wire on computer and trace it to the factory alarm module(look on a wiring diagram then test it with digital meter not a test light, but if your not a confident in car wiring get a expert !! hey jack you bored ? I dont have time or I would sort it out for ya.
the wire would either go to ground or positive to trigger the door lock relay upon reaching 25kmh or so?
https://www.sau.com.au/forums/topic/253983-r33-help/#findComment-4388020
Guest CleanAndSimple
i know for sure there is a autolock function when you go over 25km in a r33.
but there is also a feature built into viper alarms.
i have a 33 and a viper alarm. locks the second i start the car. and also if i let someone out (keeping the car on) and then drive off. locks at 25km. so i reakon it would be a bit of both doing it. search around i know theres a few diy's to disabling the 25km lock. as for the alarm as cronic said. go to the installer and ask him to disable the rest.
in my option i like it. not to often you try to open a door while moving. :)
hope this helps.
https://www.sau.com.au/forums/topic/253983-r33-help/#findComment-4388948
yea its a possitive trig to lock it.
my answer was based on this jack?
from that it would defenantly be the alarm doing it.
and there is NO simple way to stop it from auto locking (the factory option) to get around it you could use a relay system or mount some switches somewhere to turn the locking off when you dont care about loosing the rear window demister and then when you want the demister just switch it on and live with the auto locking.
PM me what model alarm you have mate and ill find the process to stop the auto locking from the alarm.thats if you dont want everyone else knowing what alarm you have.
Edited by Jack88
https://www.sau.com.au/forums/topic/253983-r33-help/#findComment-4389144
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
    • Its a well known brand in New Zealand; its a rebrand of the Rhino RAV3.  I don't know what the wiring difference *is* between the rev.1 (installed about 15 years ago) and rev.2; but as you say I would think its reasonable that it uses the same immobiliser relay circuits. I had a look but couldnt see a similar harness; but didnt move things around since I didnt want to mess with it   It was one of AVS well known Authorised Installers; I spoke to AVS themselves about it but theyre unsure hence seeking advice more so from the skyline community who are more familiar with the actual car and its wiring. Im in Auckland; but the installer is on the other side of the city so hes very reluctant to come back to even look at it to confirm something isnt connected into the wrong wire.  I dont want to drop the name since they *did* do a really good job for the most part. Everything is very tidy and he fully replaced all the alarm wiring, all the sensors, the wiring to the door motors, installed a switch which was never installed in the first place...really happy with the alarm install itself..just not this one issue. We all make mistakes, if it is the alarm, I just want my fuel pump getting proper switched, fused, power as it was; without having to shell out for an auto electrician to switch a wire and tell me it was the alarm.
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
