Hey Guys,
I've got the following 32 parts for sale
Factory ECU $50
Power FC Hand Controller Suit AP Engineering Power FC (Not Sure What Other Models It Suits) $150
Factory Rear Spoiler Good Condition (Blue) $100
RH Tail Light Good Condition Has Small Crack In Indicator Lense (Black) $50
LH Front Headlight Good Condition $50
Factory Airbox With HKS Panel Filter $50
Factory Turbo Good Condition $150
Factory Dump Pipe $20
XS Power High Mount T04E Turbo Setup With Manifold, Dump And Front Pipes And 38mm Wastegate With Screamer pipe. Turbo Suit Rebuild $200 SOLD
Trust 3 Inch Cat-Back Exhaust Good Condition (Has A Few Small Holes And A Few Scrapes) $150
gallery2973418941037062fe9.th.jpgmedgallery2973418941254ze4.th.jpgmedgallery2973418946065fo4.th.jpg
HKB Hi-cas Boss Kit Suits Nardi And Momo Steering Wheels $50
Steering Column Shroud Good Condition $20
Hi-cas Lock Bar Good Condition $50 SOLD
Factory Intake Pipe $10
Factory Crossover Pipe With Factory BOV $20
Malpassi Fuel Pressure Regulator $25
All Parts Are Located In Kenmore, Brisbane
Pickup Only
Call Dylan 0418793749
https://www.sau.com.au/forums/topic/254007-r32-parts-for-sale-brisbane/
i cannot pick up im in vic but i need a head light asap can you do us a favour and post mate cheers it would but great if you could i can pay into your account tomorrow if you give me your details cheers
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
