SK had very set ideas on suspension setup, always saying that spring rates were the
last thing that needed upgrading, and that sway bars were the key. (He would always
bring up Oran Park as the reason soft spring rates are necessary).
I wonder what he would say about these two flow diagrams which describe the tuning
process for an M3 CSL with three way adjustable shocks..
They are at the end of an illuminating PDF that has sat on the UK's foremost M3 tuning
shop.. (Thorney).
M3 is a rear wheel drive car and every car is going to be different but to me this flow diagram
looks applicable in general to any car with adjustments..
Notice that spring rates are NOT always the last on the list to get adjusted (firmer or softer).
https://www.sau.com.au/forums/topic/254115-suspension-setup/
  • Replies 45
Posted Images
yeh but they are talking about the order of adjustment, not the order of buying the parts. when u buy adjustable sway bars, alignment arms and adjustable shocks, it gives u the adjustment to play with the setup, to change spring rates u have to buy completely different springs.
What exactly are you trying to prove??
There are many different ways to sort suspension, this is obviously one way that one tunning shop uses.
I have several flow sheets similar to that with multiple different orders of importance.
Doesnt mean one is right or wrong.
Do you have one that is specific to skylines? perhaps you can post it?
I'm not trying to prove anything, but from past searches whenever suspension questions got raised the solution generally bogged down into the "sydneykid setup".. which is not available now. So I thought there should be some more info to go on.
Think the other thing to consider here is that different people like their cars to handle diferently and set the suspension up how they like, there is no set rule that MUST be followed...
Driver confidence goes a long way and thats achieved with the suspension being set up how the driver wants it, not the way that is considered "right"
I think that degree of variability is at the end. From stock I imagine most cars should get the same upgrades just like in the area of power: everyone improves a short list, the same way. And what to do first, middle and last is well understood.
But whatever.
since when is the "sydneykid setup" not available anymore? whiteline/selby still make sway bars, bilstein still make shocks, eibach/whiteline still make springs, whiteline still make alignment parts. the funny part is if u buy smart ull still pay less than what gary was charging in the group buy.
No I dont belevie in specific flow charts for specific cars. They should be seen as a guide and nothing more. Each to their own when it comes to sorting a car out.
I agree there is a criteria that people should follow when buying/upgrading parts. What you need is fairly set in stone much like engine modifications. However there is always a small minority that wont suit the general outlines. And when it comes to tuning the said parts it has to come back to the driver about any flow chart.
I know people who hire better drivers than themselves to steer the car and give input, I know people who strictly follow flow charts like that you posted, Personally, I occasoinally refer to charts but most of the time the order in which I adjust is predetermined by my own oppinion (which since im the driver is by far the most important)
I can be wrong and the car can go backwards but everything I do is logged and from mistakes I gain experiance.
Sound so oddly like something Gary once said to me.....
He has set ways for a reason. They work.
You are correct the new colour of the selby bars is so much better than the canary yellow of the past too!
I bought Gary's kit for my 32 and I was very happy with it and even bought some bigger bars from him. Sure they took some time to get here but they did make it. I think more than sell parts Gary created a discussion about suspension and the use of Australian made/sourced parts that resulted in a lot of cars with better suspensions setups and more informed drivers.
Which whiteline bits came in the kit if you don't mind me asking? did you get a product number list?
reason I'm asking is they sell more than few alternatives..
I used the front bushes at first but I ended up going for some Midori style arms...plenty adjustment :P . The GB thread has the info GB Info
As for the GB. I look at as a first step and really it is pretty much a freshen up deal for the R. I've since change and added other components...rear radius and control arms, tension rods etc. I thought the KTA117 adjustable rear upper radius arms made a big difference when I put the power down. That and the Nismo Pro TT Diff :D
Where did you get the midori "style" stuff then?
I was looking at ARC (not the titanium ARC) in japan and they have some nice fully adjustable sway kits (in choice of colors!) but the price now is like 70,000 yen per end.
suspension is an easy 5 step process... just follow my flow diagram:
1. take car to centreline
2. give keys to chris
3. say "fixy fixy" and point at car
4. open wallet...
5. drive away happy
Everyone has to be good at something, no one can be an expert at everything. Your right, leave it to the experts. Any good suspension place can take your ideas about how you want the car to handle, and make it happen.
My advice is to do the lot in one go. Why stuff around adding bits and pieces and then paying over and over for allignments. Get it installed, get the right settings put in place and go racing!
4. open wallet...
5. drive away happy
6. complain about how much u spend on ur skyline
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
