FOR SALE: R33 coilovers
Item & Condition: Tein HR Coilovers for R33 gtst. no leaks. boots in perfect condition. my gtst felt MUCH better at the track with these in, otherwise my car would understeer. These units are height adjustable
Price and price conditions: $700
Contact Details: PM me here, i'm on everyday
Delivery & Conditions of Delivery: i COULD post these but it would cost somewhere between $50-100
Pictures: coilovers.jpg
https://www.sau.com.au/forums/topic/254205-fs-r33-tein-coilovers/
I don't know their spring rate nor how many km's they've travelled as i bought them 2nd hand. apparently they had been sitting on a long term project r33 in a garage for a long time
i'm selling as i'm returning my car to stock. if you have stock suspension i'll knock $50 off. i'll be listing some other parts in the near future too, fmic, pod etc
they were on a series 1, i have no idea if series 1 / 2 are compatible, can't imagine that the suspension setup would have change *that* much
Edited by InterCooL
typical jap coilover, quite firm. i think my brother had a car (mirage) with stock shocks and lowered springs, i believe these coilovers ride much better than his setup. although my friends r34 with $3000 hks coilovers did feel nicer...
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
