  • Replies 45
my spool is fitted very happy with it almost half the weight of the oem centre yet it looks indestructable
gearbox is a powerglide
and the doors are being made in 100% carbon fibre should be ready in may (being made locally brisbane)
how long till your car hits the track???
Edited by jas/slo32
https://www.sau.com.au/forums/topic/254206-slo32/page/2/#findComment-4515214
and the doors are being made in 100% carbon fibre should be ready in may (being made locally brisbane)....
that sounds great.....can you post up the weight with windows when you get them back? Would love to know how our lightened std route compares to full CF
https://www.sau.com.au/forums/topic/254206-slo32/page/2/#findComment-4527293
Havent got the doors yet but did take the car to the weighbridge on the weekend @ race weight full fuel oil etc
car 1130kg raceweight
car with driver 1210kg
im hoping with carbon doors/bonnet/boot to get the car just under 1100kg but 30kg is alot of weight
https://www.sau.com.au/forums/topic/254206-slo32/page/2/#findComment-4538274
  • 5 months later...
Car will be for sale shortly with new engine 0 hours use
details
engine
rb26/30
grout filled block
nitrided crank
cp pistons
argo rods
arp rb26 head studs
hks 272 cams
arp bottom end studs
acl race bearings
jun oil pump
ati 1000hp balancer
ati dry sump drive (for fuel pump)
hks manifold exh
garrett gt42r
custom plenum with 100mm t/b
1800hp belt driven fuel pump/reg
12x 1600cc injectors
electrics
motec m8oo
msd dis 4
motec coils
6x egts
5 bar map sensor
all new wiring
driveline
2spd powerglide checked over rescently
new 6000rpm converter & vasco input shaft
1pc tailshaft
diff
gtr rear end
new full spool centre
new bearings
heims joint adj toe arms
body lightweight
as per previous post
gtr front guards
lexan windows
frp bonnet
frp headlights
current tech
minitubbed
parachute
14lt fuel cell
4lt catch tank
wheels
new 15x8 billett rear
new 15x3.5 billett rear
26x4 front
28x10 rear
price $40 000 ono with car trailer pm for more details
or ring 0424348521
Jason
Edited by jas/slo32
https://www.sau.com.au/forums/topic/254206-slo32/page/2/#findComment-4848287
  • 1 year later...
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
Car is now for sale as a roller minus engine,trans,tailshaft,ecu,cdi & rego plates.
Weighs 1179kg race weight with 90kg driver
car drives straight,current tech,6 point cage etc etc
$10k ono need to make way for chassis car
Phone Jason 0429232288
located bundaberg qld
https://www.sau.com.au/forums/topic/254206-slo32/page/2/#findComment-6128763
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
